In this article, you'll discover how to create a workspace in FME Workbench, the authoring application accompanying FME Form, specifically emphasizing the use of tabular data. Please follow along with the step-by-step instructions to learn how to read data from a Microsoft Excel workbook that includes employee information, add a transformer to filter for active employees, and then write the filtered data to a new worksheet in the same workbook
If you regularly use databases instead of spreadsheets, you can complete the same example by reading from a PostgreSQL database. For instructions, see Getting Started with FME Form: Working with Databases.
A rebranded interface was introduced
in FME 2024.0. This tutorial can be used with any version of FME. The concepts
are the same, but the screenshot appearances may differ.
In FME 2025.1, the toolbar menu has been organized. Readers and writers can now
be found under the Build menu. Additionally, an Add button has been added to
the canvas, where sources, destinations, and transformers can be selected.
Video
Source Data
The source dataset is a Microsoft Excel workbook containing employee information.
Step-by-step Instructions
1. Start a Blank Workspace
Start FME Workbench, then click the New button.
The FME Workbench canvas is where the workspace will be built using readers, writers, and transformers.
2. Add an Excel Reader
First, we need to add a source dataset. A reader is an object in a workspace that reads a source dataset. There are a few ways to accomplish this.
| Click on the Reader button on the toolbar | |
| On the top menu bar, click Build > Readers > Add Reader | |
| In FME 2025.1+, you can click on the canvas to add a data source. |
In the pop-up Add Reader dialog, set the following parameters:
- Format: Microsoft Excel
Dataset: EmployeeRecord.xlsx
- Click the ellipsis to browse to the location of the sample dataset on your computer
Click OK to add the reader to the workspace.
A reader object has been added to the canvas to represent the Employees worksheet. Readers create a feature type for each table or layer in the source dataset you wish to read. In this case, the Excel workbook only had one worksheet, so there is a single feature type.
The Navigator is where readers can be found.
a) This represents the dataset, such as the entire EmployeeRecord.xlsx workbook.
b) The feature types represent each part of the dataset, in this case, the worksheets.
3. Add a Transformer
Transformers are the building blocks of a workspace for manipulating data, and each has a specific function. You can add a transformer in multiple ways, similar to readers:
| Click anywhere on the blank canvas and start typing the transformer name to access the quick add menu | |
| Click on the Transformer button on the toolbar | |
| On the top menu bar, click Build > Transformers > Add Transformer. | |
| In FME 2025.1+, you can click on the green + on the canvas and select Transformer |
We will use a Tester transformer to filter the data. Type Tester in the Quick Add window. Double-click on the Tester transformer to add it to your workspace.
The data and the transformer need to be connected to access the data from within the transformer. Click and drag from the arrow on the Employees reader feature type to the red arrow of the Tester transformer. This connection line sends data from the feature type into the transformer for processing.
4. Modify Transformer Parameters
The Tester transformer filters data based on conditional statements. To filter for the employees who are still active at the company, a conditional statement of Status = Active will be created.
Double-click anywhere on the Tester transformer to open the parameters. Click on the red box below the Left Value in the Tester parameters to expose the selection options.
After clicking in the box, an ellipsis button and a down (drop-down) arrow will appear. Click on the down arrow to open the drop-down menu, hover your mouse over Attribute Value to expand the menu, then click on Status. Status is the attribute where the Active and Inactive values are stored.
Next, click in the box under Right Value; the selection options will appear but can be ignored, as we will manually enter a value. In the Right Value box, type Active. Notice that after clicking the Right Value box, the Operator changed to = (equals), which is the default operator. The Operator can be changed by clicking the =, which will open a drop-down menu. The conditional test has been set up. Click OK to confirm the Tester parameters.
Clause 1:
- Left Value: Status
- Operator: =
- Right Value: Active
5. Run Workspace
We have authored the workspace to read the data and filter for Active employees, but we still need to run it. On the top toolbar (ribbon), click the green Run button. Ensure that Enable Data Caching is checked off. Clicking Run will trigger the workspace to read and process the data through transformers.
After clicking Run, a Translation Parameter Value dialog will pop up; this is where any user-defined parameters can be modified. We do not need to make any changes now; click Run to continue.
6. View Output Data in Data Preview
After the workspace is initiated, data will flow through it. The numbers on the connection lines represent the number of features it is transporting, and the numbers on each output port represent the number of features it outputs.
The Translation Log will also open; you can ignore it for now. A feature in FME is a single row in a table. Click on the green eye icon on the Tester Passed output port to open the data in the Visual Preview window. For more information on viewing data in FME, see Data Inspection in FME.
Data Preview (formerly Visual Preview) is the data viewer within FME Workbench. There is also an external application, FME Data Inspector, that allows users to view data. In the Data Preview window, you will see the Tester_Passed table, which contains all employees with an Active status. Inspecting the Failed output port would display all of the inactive employees.
7. Add a Writer
Now, the data needs to go to a destination. The data displayed in Visual Preview is currently stored only in FME Workbench, so we need to write it out to a file for later use or to use within a different application. This is accomplished with a writer.
Like readers and transformers, there are multiple ways to add a writer to the canvas.
| Click on the Writer button on the toolbar | |
| On the top menu bar, click Build > Writers > Add Writer | |
| In FME 2025.1+, you can click on the green + on the canvas and select Destination |
In the Add Writer dialog, set the following fields:
Dataset: <local path>\EmployeeRecord.xlsx
- Click on the ellipsis and browse to the EmployeeRecord.xlsx dataset
- Sheet Definition: Automatic…
Click OK to finish adding the writer to the canvas.
The default Sheet Definition parameter for FME 2023.2 and prior is Copy from Reader. Before clicking OK, change the Sheet Definition to Automatic. Then continue to the next step.
8. Modify the Writer Feature Type
The Sheet Definition was set to Automatic, which means the schema will be copied from the workflow when we connect the writer feature type. We can modify the name before we connect it.
In the Feature Type dialog, set the following:
- Sheet Name: Active
Click OK.
The writer has been added to the canvas.
To connect it, click and drag from the arrow on the Tester Passed output port to the red arrow on the Active writer feature type.
9. Run the Workspace and View Output
The final step is to run the entire workspace. Running the workspace with a writer connected will write the data out to disk. Click on the Run button again to run the entire workspace. The Translation Parameter Values dialog will reappear since we added a writer; click on Run.
Single-click on the Active writer feature type to open the pop-up menu. Click on the folder icon to browse to the folder containing the dataset.
In your File Browser, double-click on EmployeeRecord.xlsx to open the dataset in Microsoft Excel and view the newly added Active worksheet. If you do not have Microsoft Excel installed, the dataset will open in FME Data Inspector.
The default parameters in the Microsoft Excel writer are set to insert data each time the workspace runs. If the workspace were run a second time, a duplicate copy of the active employees would be added to the newly created Active worksheet. To learn more about the Microsoft Excel writer, see Excel Writer Parameters | Converting Excel to Excel.
Continue Your FME Journey
- Getting Started with FME Form: Working with Databases
- Getting Started with FME Form: Working with Spatial Data
- Getting Started with FME Form: Working with Web Data
Want to learn about a specific format?
- Tutorial: Getting Started with Excel
- Tutorial: Getting Started with CSV
- Tutorial: Getting Started with Apache Parquet
Want to continue learning FME Form basics?
- The FME Academy is a guided, on-demand way to learn the entire FME Platform, and it's FREE!
Interested in self-serve and automation?
Have a specific question?
- Reach out to the FME Community
Data Attribution
The data used in this example was randomly generated with generatedata.com. This dataset is a work of fiction. Names, dates, places, and incidents are randomly generated. Any resemblance to actual locales or persons, living or dead, is entirely coincidental.
