Tutorial: Getting Started with CSV
Liz Sanderson
Liz Sanderson
Comma Separated Value, or CSV, is a way to store structured information in an ASCII file format, thereby making it a very simple database. This has made it a very popular format for exchanging information between spreadsheets, databases and other software systems.
In FME, CSV is treated as a database format. Each line in the file is a record, with a comma (or other) character between each field within the record.
In the CSV file, there is often a header line to provide names for the fields. For example:
Example of a CSV file viewed in a text editor like Word Pad
If you check the parameter Field Names Line, you can select which line the column names start on, for this example it is Line 1, but sometimes you could have lines of text at the beginning of the CSV file.
The same CSV file preview in the CSV reader parameters in FME
Delimiters
Despite the name, a CSV file does not have to be comma-separated. FME is capable of recognizing a file with any separator or delimiter character, as long as you specify that character in the settings box.
The CSV reader is also capable of handling data consisting of fixed-width columns without a separator, provided that the character spacing the data (usually a space character) does not appear in the data itself. Simply use the parameter 'Remove Duplicate Separators' to achieve this. For more information, please see the CSV Reader documentation.
Translating Tabular Data
FME can translate CSV data into other tabular formats, such as Excel, Oracle, SQL Server, or XML.
Turning Text Data into Spatial Data
CSV files often contain spatial data listed as a series of X/Y coordinates. When a coordinate system is added to a CSV reader, FME will create spatial points from the X/Y values. If you want to create lines or polygons from these points, see the Converting from CSV to Spatial Geometry article for instructions.
If your workflow does not require spatial data, you can simply add the CSV file without a coordinate system, and the dataset will remain unchanged as plain tabular data.
Tutorials
Viewing and Inspecting CSV Data
This example will demonstrate how to view both a tabular CSV file and a spatial CSV file using FME Workbench and the Data Inspector.
How to Convert CSV to Microsoft Excel
Learn how to convert a CSV file to Microsoft Excel format and do simple attribute manipulation, including date-time formatting.
Converting from CSV to PostgreSQL and PostGIS
Using FME to convert CSV files to both PostgreSQL and PostGIS is easy. This example demonstrates how to handle CSV data with a delimiter other than a comma.
This example is a brief overview of how to convert CSV data with latitude and longitude values, or addresses, into points, lines, or polygons.
How to Convert CSV to Shapefile (Non-spatial to Spatial)
Shapefiles have a 10-character limit on attribute names. This example demonstrates how to convert CSV to Shapefile, as well as how to map attributes between the reader and writer when attribute names are truncated.
Converting Tabular (Non-Spatial) and Spatial Data to CSV
CSV files are versatile and are an accessible way to share data. Learn how to convert both tabular and spatial data into CSV format.
Advanced Tutorials
Build Road Lines from GPS Points (CSV to Shapefile)
Most GPS data is acquired in point form. Learn how to create lines from GPS points contained in a CSV file and then store the lines in a Shapefile.
Attribute Processing Example Workspace (CSV to MapInfo)
In this example, learn how to use various transformers to manipulate CSV data before outputting it to MapInfo Tab. This example can easily be adapted to transform data to a tabular output format instead of a spatial output format.
Join CSV File to a Database Table with the DatabaseJoiner
Data can come from various sources, learn how to use a DatabaseJoiner to join a CSV file to a Microsoft Access file.
Using Google's Chart API to Create Charts from a CSV and Shapefile
There is a lot you can do with Google APIs. In this example, we will create a pie chart from a CSV file and a Shapefile and display it in Google Earth.
Resources
CSV Quick Facts
CSV Reader/Writer Documentation
