Getting Started with BC MoF ESF
Liz Sanderson
Liz Sanderson
The BC Ministry of Forests (MoF) Electronic Submission Framework (ESF) is a set of XML/GML formats that enable clients to submit data electronically to the BC Ministry of Forests and Range, as well as the Ministry of Agriculture and Lands. This article supplies some resources for getting started with this format.
ESF Training Resources
In addition to the ESF templates available on the website, the ESF training also includes a range of ESF examples of FTA and Results submissions, complete with source data, workspaces, and output datasets. This way, you can see what FME starts with and what it needs to generate. You can download this from: MoF_ESF_Training.zip
There are now ESF-specific readers available, such as FTA, ABR, and Results.
FME Basics
The first question is, have you used FME before? If not, I would highly recommend starting off by first downloading the tutorial from: http://www.safe.com/support/onlinelearning/overview.php
This will help you get a feel for how FME Viewer and Workbench work. In particular, it will help you get your feet wet with some basic examples.
Remember that FME is a data flow translation tool, and it's important to understand how features flow from the source datasets and their feature types to your destination feature types. For example, in FME, spliting data flow is the same as copying and combining is the same as appending. If you want records to actually merge attributes or features together, then you need to use combining transformers such as Aggregators, FeatureMergers and Joiners, etc.
ESF Tutorial Examples
Once you have reviewed the FME tutorial, it would probably be a good idea to see if you can get one of the ESF training examples to work. I would suggest starting with the FTA_HA example. Create a backup copy of the ESF example output and ensure you can generate similar results.
Note that the key to ESF submissions is building the right ID keys so that there are logical relational links between the various esf_ids (esf_legal_description_id, esf_harvest_application_id in the case of FTA). Usually, if a submission fails, it's because one of these IDs is missing or doesn't match up with the associated table record or geometry feature it's supposed to be associated with. You need to populate the various esf_ application and block IDs so that the nested object structure and relationships are defined correctly.
Harvest Application Example
For example, in the FTA_HA example from the ESF tutorial (HarvestApplication_wCP_submission.xml):
 The harvest application has :
 esf_harvest_application_id hawcp-1
 esf_legal_description_id legal-desc-1
 and cutblock A has:
 esf_legal_description_id legal-desc-3
 and cutblock B has:
 esf_legal_description_id legal-desc-2
This means that cutblock A and B both belong to harvest application hawcp-1 and hence define the relationship between the cutblock objects and the harvest application object. Also, all the legaldescription ids need to be defined as individual records in the legaldescription feature table.
Viewing Output
When you do generate a result, try opening it with the FME Viewer using the appropriate ESF reader format. If the results look good, you can always go to the settings subform and check the validate box. This applies the same schema check that the MOF ESF submission website subjects your online submission to, and will fail unless everything is ok with your xml.
Once you understand the esf tutorial, you can take another shot at the ESF submission. As the movie explains, the template is not a solution but rather a starting point that just shows the destination datasets that need to be populated (some are optional). You may choose instead to start with one of the FTA or Results examples (whichever you need) from the ESF training, delete the source node feature types (data set layers or feature classes), and import feature type definitions from your source shape and excel files.
Reading Nonspatial Tabular Data
Normally, FME can read CSV or Excel files that are simple flat tables with one header row at the top that contain the field names. You may need to copy and paste some of your tables from a multi-tab Excel file into a separate Excel or CSV file. Remember to go into the reader settings and choose 'Read fieldnames from first row' (or skip the first row).
Problems
If you run into trouble, try going through BC MoF ESF format Problem Solving.
Summary
So to sum up, you need to read your submission metadata from a table, such as a CSV or DBF file, and write that to the ESF metadata feature classes. Then you need to read your cut block and harvest application polygons, and then build the necessary nonspatial and spatial feature classes and use attribute renamers to map your input fields to the correct output fields in the destination template. Also, you need to populate the various esf_ application and block IDs so that the nested object structure and relationships are defined correctly. The idea is not to create your own GML, which wouldn't be compliant with the ESF schema, but rather to write both attribute records and geometry to the appropriate feature types according to the ESF schema so that all the information is contained in one XML document file.
