Java4Shell: FME Platform Under Investigation (CVE-2026-114938)
Kezia Yu
Kezia Yu
Status Under Investigation
Last Updated November 24th, 2026
Summary
On November 17, 2026, researchers at Calif disclosed Java4Shell (CVE-2026-114938), a critical memory-corruption vulnerability (CVSS 4.0 score of 9.2) in OpenJDK’s Base64 decoder. A remote attacker with no credentials can send malformed Base64 input to overwrite heap memory, leak sensitive data, and in some cases achieve remote code execution. The researchers demonstrated working exploits against several widely deployed Java applications, but the application-specific exploits have not been published. The flaw affects OpenJDK 17.0.6 through 17.0.21 and 21.x through 21.0.13 (also 25.x and 27.x), and the distributions built from it (Oracle Java SE, Amazon Corretto, Eclipse Temurin and others), but only on x86-64 processors with AVX-512 VBMI support (Intel Ice Lake or later, AMD Zen 4 or later). ARM64 systems are not affected. Fixed OpenJDK builds (17.0.21.1, 21.0.13.1, 25.0.5.1 and 27.0.1.1) were released on November 17, and Eclipse Temurin has begun publishing fixed builds.
Why This Matters for All Deployments
This is not a defect in FME, but FME ships a Java runtime, so any FME deployment running on affected hardware inherits the vulnerability until the runtime is updated. Applications that bundle their own Java runtime, including FME, need to be updated separately from the operating system. Java processes that decode attacker-controlled Base64 input are the most exposed, and web-facing services such as FME Flow handle this kind of input as part of normal operation. Whether the flaw can be triggered depends on the host's CPU; how reachable it is depends on how the deployment is configured. Exposure is highest for FME Flow instances reachable from untrusted networks.
Impact on Safe Software
  • FME Form: FME Form releases 2023.1 through 2026.3.x are affected. The Windows and macOS installers bundle Temurin, and a number of formats use the vulnerable decoder. On Linux, Form uses the system Java runtime, so Linux users should update that runtime. Apple Silicon (ARM64) Macs are not affected.
  • FME Flow: FME Flow releases 2024.0 through 2026.3.x are affected. Bundles Eclipse Temurin in its Windows and Linux installers, the Remote Engine, and its Docker images.
    • Safe Software is actively assessing exploitability in FME Flow. Our initial analysis indicates that unauthenticated input reaches the vulnerable decoder on some endpoints, so we are treating FME Flow as likely exposed to at least a remote denial of service. We have not confirmed remote code execution.
  • FME Flow Hosted: FME Flow running on FME Flow Hosted is not affected. FME Flow Hosted instances are deployed on the AWS M5 instance family and do not have AVX-512 VBMI support.
  • Safe Software will ship the fix to Java4Shell in FME 2026.4 LTS, as new installers. See Coming Soon: FME 2026.4 Long-Term Support (LTS) in December.
Recommended Precautions
  • Check your hardware: The vulnerability only triggers on CPUs with AVX-512 VBMI. Hosts that do not report it are not exposed. ARM64 hosts are not affected. See Check whether your host is affected below.
  • Limit exposure: Where possible, keep FME Flow off the public internet and behind a reverse proxy, VPN or allow-list, especially on hosts that report AVX-512 VBMI.
  • Update Java: For FME Form on Linux, and for other Java applications, apply the fixed Java builds from your vendor now. The Java runtime bundled with FME Form (Windows and macOS) and FME Flow can only be updated through a new FME release. Updated FME builds are not available yet.
  • Interim mitigation: Until updated FME builds are available, see below.
Interim Mitigation
FME Flow
Before you begin
  • CVE-2026-114938 (Java4Shell) is an out-of-bounds write in the Base64 decoder of the Java runtime. FME Flow 2024.0 and later ship an affected Eclipse Temurin runtime on Windows, Linux and in the Docker images.
  • The vulnerability fires only on x86-64 CPUs that support the AVX-512 VBMI instruction set, for example Intel Ice Lake or later and AMD Zen 4 or later. ARM64 hosts are not affected. See Check whether your host is affected to test a host.
  • The mitigation is the Java option -XX:-UseBASE64Intrinsics. Adoptium, the vendor of the Java runtime, recommends this option as the workaround. With this option the Java runtime decodes Base64 in plain Java code instead of the affected CPU-specific code. Safe Software supports this workaround. In our testing, it caused no side effects.
  • Apply the steps to every host that runs FME Flow, including each Remote Engine host (relevant for distributed installs).
  • The steps require restarting FME Flow services.
  • <FlowDir> is the FME Flow installation folder. <SystemShare> is the FME Flow System Share folder chosen at install time, for example C:\ProgramData\Safe Software\FMEFlow or /data/fmeflowdata.
  • In a distributed installation, apply the steps from this guide on every host that runs an FME Flow component, then verify on every host. Each host needs only the steps for the components it runs.
If avx512_vbmi does not appear anywhere in the output, the host cannot be exploited.
  1. On Linux, run grep -o -w avx512vbmi /proc/cpuinfo | head -1
  2. On Windows, run <FlowDir>/Utilities/jre/bin/java -Xlog:os+cpu=info -version
Windows
Steps
  1. Open Control Panel > System > Advanced system settings > Environment Variables.
  2. Under System variables, click New.
  3. Enter the variable name JAVA_TOOL_OPTIONS and the value -XX:-UseBASE64Intrinsics, then click OK in each dialog.
  4. Open Services and restart FMEFlowAppServer, FME Flow Core, and FME Flow Engines.  A running service does not read a new system variable until it restarts.
  5. NOTE: Please remove the environment variable upon upgrading to a fixed Flow version.
Verify
  1. Open the newest file named catalina.<date>.log in the Flow UI under Resources\Logs\tomcat\<hostname>. A line after the restart must contain Command line argument: -XX:-UseBASE64Intrinsics
    1. This confirms that Tomcat has picked up the new configuration parameter and effectively disables the vulnerable code path.
  2. In the Flow UI open Resources\Logs\core\current\fmeprocessmonitorcore.log. Look for logs that contain Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
    1. This confirms that the new configuration parameter has been picked up for each Core Java process and effectively disables the vulnerable code path.
  3. To test that the Engine processes have picked up this change, first run a workspace that loads a Java plugin (eg. WebSocketConnector). In the Flow UI open Resources\Logs\engine\current\fmeprocessmonitorengine.log. Look for a line that contains Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
    1. This confirms that the new configuration parameter has been picked up for Engine processes and effectively disables the vulnerable code path.
  4. Log in to the FME Flow web interface and run a workspace.
Linux
Steps
These steps set JAVA_TOOL_OPTIONS in the start script of each FME Flow component in <FlowDir>/Server. Every way of starting FME Flow on Linux runs these scripts: the systemd units, the SysV scripts in /etc/init.d and startServer.sh. An upgrade, <FlowDir>/Utilities/renderConfigFiles.sh and <FlowDir>/Utilities/configureSSL.sh regenerate the scripts and remove the line. Add it again after any of these run until you install a fixed build.
  1. Back up startApplicationServer.sh, startCore.sh, startWebSocketServer.sh, startEngines.sh, and startCleanup.sh in <FlowDir>/Server.
  2. In each of the 5 files, add this line directly below the first line, #!/bin/sh:
    export JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics
  3. Restart the Flow services mentioned above.
    1. For example, if FME Flow starts with startServer.sh, stop it and start it again with:
      sudo <FlowDir>/Server/stopServer.sh
      sudo <FlowDir>/Server/startServer.sh
Verify
  3. Since the Websocket and Cleanup processes are started separately on Linux, also verify that the Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics line is logged in Resources\Logs\service\current\fmeprocessmonitorcleanup.log and Resources\Logs\service\current\fmeprocessmonitorwebsocket.log
  4. To test that the Engine processes have picked up this change, first run a workspace that loads a Java plugin (eg. WebSocketConnector). In the Flow UI open Resources\Logs\engine\current\fmeprocessmonitorengine.log. Look for a line that contains Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
  5. Log in to the FME Flow web interface and run a workspace.
Docker
Steps
  1. In docker-compose.yml, add JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics to the environment section of the fmeflowweb, fmeflowcore, fmeflowwebsocket, and fmeflowengine services. If your file also has fmeflowutility, fmeflowenginedynamic, or other engine services, add the variable to them as well.
  2. Run docker compose up -d. Compose recreates the containers whose configuration changed.
Verify
  3. Also verify that the Websocket and Cleanup processes are started with the new configuration parameter by checking that the  Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics line is logged in Resources\Logs\service\current\fmeflowcore_fmeprocessmonitorcleanup.log and Resources\Logs\service\current\fmeflowwebsocket_fmeprocessmonitorwebsocket.log
  4. To test that the Engine processes have picked up this change, first run a workspace that loads a Java plugin (eg. WebSocketConnector). In the Flow UI open Resources\Logs\engine\current\<id>_fmeprocessmonitorengine.log where id is the Engine that ran the job. Look for a line that contains Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
Kubernetes
Steps
  1. Find the workload names. Run:
    kubectl get statefulsets,deployments -n <namespace>.
    Web, core and the utility engine run as containers in one StatefulSet, usually named core. WebSocket runs in its own StatefulSet, usually named websocket. Each engine group runs as its own Deployment, for example engine-<group>.
  2. Set the environment variable JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics on the core StatefulSet, the websocket StatefulSet and each engine Deployment. Run this command for each workload:
    kubectl set env <workload> JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics -n <namespace>
    This command sets the variable on every container in the pod. One command on the core StatefulSet covers web, core and the utility engine together.
    1. Example command: kubectl set env statefulset/websocket      JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics -n fmeflow
  3. Helm does not track this change. Some Helm operations, such as helm upgrade --force or a reinstall, remove it, and a helm upgrade that adds an engine group creates a new Deployment without it. After every helm upgrade, list the workloads again and run the command above on each one, even if the variable already appears to be set. If a workload already has the variable, the command changes nothing and does not restart its pods. Do this until you install a fixed build.
  4. Wait for the pods to roll.
Verify
  1. Open the newest file named catalina.<date>.log in the Flow UI under Resources\Logs\tomcat\<podHostname>. A line after the restart must contain Command line argument: -XX:-UseBASE64Intrinsics
  2. In the Flow UI open Resources\Logs\core\current\<podHostname>_fmeprocessmonitorcore.log. Look for logs that contain Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
  3. Also verify that the Websocket and Cleanup processes are started with the new configuration parameter by checking that the Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics line is logged in Resources\Logs\service\current\<podHostname>_fmeprocessmonitorcleanup.log and Resources\Logs\service\current\<podHostname>_fmeprocessmonitorwebsocket.log
  4. To test that the Engine processes have picked up this change, first run a workspace that loads a Java plugin (eg. WebSocketConnector). In the Flow UI open Resources\Logs\engine\current\engine-<group>-<id>_fmeprocessmonitorengine.log. The relevant log file is for the Engine that ran the workspace. Look for a line that contains Picked up JAVA_TOOL_OPTIONS: -XX:-UseBASE64Intrinsics
FME Form
The JVM option -XX:-UseBASE64Intrinsics disables the vulnerable code path. Do not use -XX:UseAVX=2, because the JVM will not start with it on ARM64.
  • Windows and macOS: set JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics in the environment before launching FME, then restart FME.
  • Linux: Form uses the system Java runtime, so the preferred fix is to update that runtime. As a stopgap, set JAVA_TOOL_OPTIONS=-XX:-UseBASE64Intrinsics in the environment from which FME is launched.
  • Until Form is updated, use the Java and JDBC formats only against trusted data sources.
Across the software industry, AI-assisted research is finding vulnerabilities faster than ever. To keep pace, we're changing how we deliver security fixes. Starting with FME 2026.4, one FME release each year will be designated a Long-Term Support (LTS) release. An LTS release receives critical and security fixes for an extended period, so you no longer need a major upgrade each time to stay protected. We'll share more details in a dedicated announcement shortly.
What to expect
  • First LTS release: FME 2026.4, planned for mid-December 2026.
  • Java4Shell fix included: FME 2026.4 will include the fix for Java4Shell (CVE-2026-114938). Until you can upgrade, we recommend considering the interim mitigation described above.
  • Two years of security fixes: Each LTS release will receive critical fixes for two years after its release. Fixes are delivered as updates to that release (for example, 2026.4.1 or 2026.4.2), so staying on the latest 2026.4 update keeps you covered.
  • Simpler updates for FME Flow: FME Flow 2026.4 introduces in-place minor upgrades, which will make many future 2026.4 updates easier to apply. Moving to 2026.4 is a standard upgrade, and depending on the type of changes required, some later updates may still require a full reinstall. Wherever a critical fix cannot be made available as an in-place upgrade, we will endeavour to provide a manual patch file-based or equivalent remediation option that can be applied without reinstalling FME Flow.
  • What comes next: We plan to make the December (.4) release the LTS each year. The current quarterly release will also continue to receive fixes alongside LTS releases in their support window.
Planning your upgrade
If you're planning an FME upgrade, we recommend targeting FME 2026.4. It gives you a single, stable release to standardize on, with long-term security fixes and, for FME Flow, a much easier way to apply many of them. If you're waiting for the LTS before upgrading, we recommend considering the interim mitigation above in the meantime and keep FME Flow off untrusted networks where possible.
Our Product Support Policy will be updated alongside the LTS announcement. To be notified, subscribe to our Security Updates email list on our Security page.
