OGC MUDDI Standards Tutorial Part 1: MUDDI Burnaby Loader
Trent Kading
Trent Kading
Underground mapping has been a challenge simply because underground features and assets are much more difficult to survey or collect data for. On the other hand, the lack of good underground data can result in costly damage to critical infrastructure, public safety impacts and harm to the environment. The OGC MUDDI standard - Model for Underground Data Definition and Integration - was developed to address these and related challenges  - the mapping of underground features and infrastructure better protects infrastructure, people, and the environment, and avoids costly damage during construction and maintenance activities.
The application developed in this tutorial is meant to demonstrate an application that can be used to examine a specific site for underground utilities prior to a planned excavation. This way steps can be taken to avoid damage to the underlying utility infrastructure. This specific use case integrates data from a variety of utilities, including water supply, electricity, telecom, wastewater and storm drains.
The tutorial is divided into two parts: the MUDDILoader and the MUDDIExcavationReporter. This tutorial covers the first exercise - loading the data from various utilities into the MUDDI data model stored in an OGC geopackage.
Below, we will go over the steps to populate an OGC Geopackage that is utilizing the MUDDI data model. Using data across various utility sectors, such as water, electrical, sewer, and telecommunications - you will learn the basic process of how to move from GIS data into a MUDDI-modelled Geopackage.
Downloads
Step-by-Step Instructions
Part 1: City of Burnaby Infrastructure GeoJSON Data
In this part, we will cover how to move City of Burnaby GeoJSON data into a MUDDI-modelled Geopackage.
1. Start FME Workbench and Add GeoJSON Data
Start FME Workbench and click on New to open a blank workspace.
First, we need to add a Source dataset. Click on the Reader button. In the Add Reader dialog, enter the following:
  • Format: GeoJSON
  • Dataset:
    • Data/Part 1/Sanitary_Fittings.geojson
    • Data/Part 1/Sanitary_Main_.geojson
    • Data/Part 1/Sanitary_Service_Line.geojson
      • Click on the drop-down arrow and select Select Multiple Folders/Files. From there, click Add Files and browse to the desired datasets. Select all that apply.
Repeat the above steps for the Watermains, Storm Fittings, and Storm Service Lines.
  • Format: GeoJSON
  • Dataset:
    • ./Watermain.geojson
    • /Storm_Fitting.geojson
    • /Storm_Service_Line.geojson
2. Modify Schema to match MUDDI Geopackage
Add a Cloner to the output of the source GeoJSON feature types. Leave parameters as default.
Add a BulkAttributeRenamer to the output of the Cloner. Set the following parameters:
  • Rename: All Attributes
  • Action: Change Case
  • Mode: Rename
  • Case Change Type: lowercase
3. Date handling
Add a StringReplacer to the output of the BulkAttributeRenamber. Set the following parameters:
  • Attributes: instdate
  • Mode: Replace Text
  • Case Sensitive: No
  • Text to Replace: -07:00
Add a Tester to the output of the StringReplacer. Set the following parameters:
  • Left Value: instdate
  • Operator: Attribute Has a Value
  • Logic: OR
  • Left Value: install_date
Add a DateTimeConverter to the Passed port of the Tester. Set the following parameters:
  • Datetime Attributes: instdate
  • Input Format: %Y-%m-%dT%H:%M:%SZ$
  • Output Format: %Y%m%d (FME date)
  • Repair Overflow: Yes
  • Passthrough Nulls, Empties, or Missing: No
Add a second DateTimeConvert to the Failed port of the Tester. Set the following parameters:
  • Datetime Attributes: install_date
  • Input Format: <Auto detect FME and ISO formats>
  • Passthrough Nulls, Empties, or Missing: Yes
Add a DateTimeStamper to the Output and Rejected Ports of the first DateTimeConverter and the Output port of the second DateTimeConverter. Set the following Parameters:
  • Type: Date
  • Time Zone: Coordinated Universal Time (UTC)
  • Include Fractional Seconds: Yes
  • Update Time: Each Feature
  • Output Format: ISO
  • Output Attribute: systemloaddate
4. Filter Features to MUDDI Classes
Add a FeatureTypeFilter to the output port of the DateTimeStamper. Open the Parameters and Click Update. This should populate the Feature Types that you are reading in. If this does not fully populate a list you can type each of your input Feature types.
  • Feature Type Names:
    • Sanitary_Main_
    • Sanitary_Service_Line
    • Sanitary_Fittings
    • Watermain
    • Storm_Fitting
    • Storm_Service_Line
Part 2: waterpipe MUDDI Class
Add an AttributeValueMapper to the Watermain port of the FeatureTypeFilter. Set the following parameters:
  • Attribute Selection:
    • Input Attribute: material
    • Output Attribute: material
  • Mapping Direction: Forward (Input To Output)
  • Input Value Output Value
    CI Cast Iron
    ACP Asbestos Cement
    DI Ductile Iron
    STL Steel
    CU Copper
Add an AttributeManager to the output of the AttributeValueMapper. Set the following parameters:
Input Value Output Attribute Value Type Action
install_date dateofinstallation   date Rename
untid recordid   buffer Rename
diameter diameter_width   int64 Rename
  dataowner City of Burnaby varchar(15) Set Value
  dataprovider City of Burnaby varchar(15) Set Value
  systemid @UUID() varchar(200) Set Value
  name recordid varchar(200) Set Value
  diameter_unitofmeasure Millimetres varchar(11) Set Value
  lifecyclestatus Submitted varchar(9) Set Value
  horizontalcrs 4326 unit16 Set Value
  businesscontact City of Burnaby varchar(15) Set Value
  datalastupdated systemloaddate varchar(200) Set Value
  material pipetype buffer Set Value
  startingdepth_unitofmeasure Metres varchar(6) Set Value
  endingdepth_unitofmeasure Metres varchar(6) Set Value
  utilitytype Water varchar(5) Set Value
Part 3: sewerpipe MUDDI Class
Add another AttributeValueMapper. Connect the Sanitary_Main_, Sanitary_Service_Line, Storm_Service_Line to the new AttributeValueMapper_2. Set the following parameters:
    CI Cast Iron
    ACP Asbestos Cement
    DI Ductile Iron
    STL Steel
    CU Copper
    PVC PVC`
    HDPE HDPE
Add an AttributeManager to the output of the AttributeValueMapper_2. Set the following parameters:
pipediam diameter_width   int64 Rename
upselev depth   real64 Rename
dwnelev downstreamdepth_depth   real64 Rename
  utilitytype Sewer varchar(5) Set Value
  recordid unitid varchar(6) Set Value
Part 4: sewernetworkappurenance MUDDI Class
Add a TestFilter. Connect the Sanitary_Fittings and Storm_Fitting from the FeatureTypeFilter to the TestFilter. Set the following parameters:
  • Test:
    • If:
      • mhdpth ATTRIBUTE_VALUE_NULL OR mhdpth ATTRIBUTE_IS_MISSING
      • Output Port: sewernetworkapputenance
    • Else If:
      • mhdpth ATTRIBUTE_HAS_A_VALUE
      • Output Port: access
Add an AttributeManager to the sewernetworkappurtenance output port of the TestFilter. Set the following parameters:
  name unitid buffer Set Value
  recordid unitid buffer Set Value
  appurtenancetype Other varchar(5) Set Value
  dataofinstallation instdate varchar(200) Set Value
Add an AttributeManager to the access output port of the TestFilter. Set the following parameters:
  accesstupe Manhole varchar(7) Set Value
6. Assign a Unique Identifier
Add a UniqueIdentifierGenerator to each output port of the previous AttributeManagers. Set the following parameters:
  • Unique Identifier Type: Universally Unique Lexicographically Sortable Identifier(ULID)
  • Generated ID: systemid
7. Add a Geopackage Writer
Add a writer to the workspace. In the Add Writer dialog, set the following:
  • Format: OGC Geopackage
  • Dataset: Burnaby_MUDDI_SLM.gpkg
  • Table Definition: Import from Dataset
From there, open up the Parameters and set the following:
  • Overwrite Existing Geopackage: Yes
  • Template: .\Burnaby_MUDDI_SLM_Template.gpkg
  • Coordinate System: EPSG:4326
  • Always Create Tables: Yes
Click OK twice.
Now an Import Writer Feature Types dialog will appear. Change the Dataset, and point it to the Template we set earlier.
  • Dataset: .\Burnaby_MUDDI_SLM_Template.gpkg
  • Parameters:
    • Tables:
      • access, waterpipe, sewerpipe, sewernetworkappurtenance
        • Click the ellipsis button to select tables
Click OK. This should add all the Feature types we will use for this tutorial.
Connect the waterpipe Feature Type to the UniqueIdentifierGenerator from the Watermain stream.
Connect the sewernetworkappurtenance Feature Type to the UniqueIdentifierGenerator from the sewernetworkappurtenance stream.
Connect the access Feature Type to the UniqueIdentifierGenerator from the access stream.
Connect the sewerpipe Feature Type to the UniqueIdentifierGenerator from the Sanitary/Storm stream.
The workspace should now look like this:
Data Attribution
The data used here originates from data made available by the City of Burnaby, British Columbia. It contains information licensed under the Open Government License - Burnaby.
