Esri ArcGIS Utility Networks FAQ
Trent Kading
Trent Kading
This article addresses common questions from FME users working with Esri ArcGIS Utility Networks (UN). It is a supplementary article to the FME & Esri ArcGIS Utility Network Tutorial Series, which provides background, terminology, prerequisites, requirements, and tutorial articles on using ArcGIS Utility Networks with FME.
FAQ
Can I update my Utility Networks’ underlying Geodatabase directly?
It is not recommended to update your Utility Networks’ underlying Geodatabase directly, as this approach can lead to data integrity issues and in some cases, corrupt networks. For more information, see the following documentation published by Esri.
Geodatabase system tables
Dataset system tables
Additional Resources
