DropboxConnector Deprecation
Donal Mateer
Donal Mateer
On January 1, 2026, Dropbox updated their API servers to use certificates issued from a new root. As a result, the legacy DropboxConnector no longer works in any version of FME. Any workflow using the legacy connector will produce an error, see the Support section below for details based on your FME version.
Support
For more information, please review the Dropbox API server root certificate changes coming in 2026 article.
FME 2026.1.1 and newer:  You will see the following error in the FME log:
This version of the DropboxConnector was retired on December 31, 2025 due to Dropbox API changes. Please upgrade your transformer to the latest version of the DropboxConnector. For more information, refer to https://fme.ly/DropboxDeprecation
FME 2026.1.0 and older:  The above error message was introduced in 2026.1.1. On older versions, you will instead see the following error in the FME log:
com.dropbox.core.NetworkIOException: (certificate_unknown) PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
To ensure continued functionality, you must update your workflows to use the latest DropboxConnector. The new Dropbox Connector is available on the FME Hub, or you can download the latest version directly. This updated connector is required to remain compatible with any changes to the Dropbox API.
