ArcGIS Utility Network Data Generating HTML Report
Dave Choi
Dave Choi
As of FME 2024.0, support for Esri ArcGIS Online (AGOL), ArcGIS Enterprise Portal, and ArcGIS Server Feature Service formats has transitioned to a unified approach using the new Esri ArcGIS Feature Service (Format). This format replaces the legacy reader/writer formats for each of the three services.
Starting in FME 2026.3, the legacy formats will be hidden in the Quick Add menu. Instead, equivalent functionality is now provided by the downloadable Esri ArcGIS Connector package, available on FME Hub. The package also includes new web services and key transformers such as the ArcGISOnlineConnector, ArcGISAttachmentConnector, and ArcGISBranchVersionManager. The package can be installed directly through the Quick Add menu in FME Workbench. Once installed, the new Esri Feature Service format will appear in the Gallery as a unified method for interacting with all three types of Esri ArcGIS Feature Services.
For details on this transition, including guidance on updating existing workspaces, please refer to the article: Working with Esri ArcGIS Feature Services in FME.
Generating reports from utility network data in ArcGIS is essential for utilities and organizations managing complex network assets. These reports provide valuable insights into the network's state, asset inventory, and other critical information. With FME, users can create comprehensive reports in various output formats, such as PDF, Microsoft Word, HTML, and other formats supported by FME.
This tutorial will provide a brief demonstration of FME's report generation capabilities by guiding users through the process of creating a simple HTML report that includes charts, tables, and a web map.
While the scope of the report can encompass any desired attributes and information, this tutorial will specifically focus on generating a report that highlights attributes with dirty areas within the utility network data.
For a deeper understanding of generating reports or customizing HTML reports, refer to the hyperlinked documentation.
Brief Description of this Tutorial
This tutorial is designed to demonstrate how to create simple reports of Utility Network Data using the HTMLReportGenerator transformer in FME. The tutorial will utilize a pre-prepared workspace that retrieves updated, inserted, and deleted features from a data source and rectifies the data for human readability.
However, you can also follow along with this tutorial using your own configured workspace. Your workspace should be set up to retrieve updated, inserted, and deleted features from a File Geodatabase, ArcSDE Geodatabase, and/or Esri ArcGIS Portal Feature Service. Additionally, ensure that your workspace resolves domain values and rectifies the data for human readability before generating the report.
By following this tutorial, you will learn how to leverage the HTMLReportGenerator transformer to create informative and visually appealing reports from your Utility Network Data, with a specific focus on using Esri ArcGIS Portal Feature Service for change detection and identifying features within dirty areas. This knowledge can be applied regardless of whether you use the provided workspace or your own configured workspace.
Requirements
Sources
  • Report_Part1.fmw contains the completed workspace for this part of the tutorial. To make the workspace usable, the portal URL, Credentials, Feature Service, Layers/Feature Types, and Branch Versioning For Readers need to be reconfigured.
  • Report_Completed.fmw contains the completed workspace for this tutorial. To make the workspace usable, the portal URL, Credentials, Feature Service, Layers/Feature Types, Branch Versioning for Readers, and Output location of HTML will need to be reconfigured.
Step-by-Step Instructions
Part 1: Loading Workspace
1. Load the Workspace that is Configured to Retrieve Updated, Inserted, and Deleted Features from ArcGIS Utility Network Data and Rectify Resolved Domains
Open FME Workbench and configure the workspace for retrieving updated, inserted, and deleted features from a File Geodatabase, ArcSDE Geodatabase, and/or Esri ArcGIS Portal Feature Service, resolving for domains and rectifying for human readability.
Alternatively, you can open FME Workbench and load the workspace from the source that has been prepared for this tutorial. This workspace should already have the updated, inserted, and deleted features retrieved using the ChangeDetector transformer and resolved for domain values.
However, you cannot run this workspace due to the portal feature service configuration for this workspace, unless you specify your own data sources. This workspace will be used for this tutorial.
2. Review the Workspace
If you are using the tutorial configured workspace, to rectify the data sources and make the workspace runnable, you need to configure the reader parameters to match your specific data sources:
  • For the ArcGIS Portal Feature Service reader, update the "Dataset" parameter to point to your organization's ArcGIS Portal URL and specify the appropriate feature service.
Part 2: Preparing Attributes for Human Readability and Elements for HTML
1. Add an AttributeManager to the workspace
This step prepares for the popup information for the web map in the HTML. Continuing in the same workspace as Part 1, add an AttributeManager to the workspace canvas and connect it to AttributeManager_2, which is connected to the PythonCaller.
In the AttributeManager_3 Parameters dialog:
A. Create a New Output Attribute and specify the name as: Information
B. For the value, open a text editor and specify: Asset ID:@Value(assetid), Global ID:@Value(GLOBALID)
C. Click on “OK”.
2. Add a DateTimeConverter to the workspace
Add a DateTimeConverter to the workspace canvas and connect it to AttributeManager_3.
In the DateTimeConverter Parameters dialog:
A. Select desired Date Attributes for DateTime Attributes
  • For this tutorial, all the Date Attributes will be selected, these include:
    • creationdate
    • inservicedate
    • installdate
    • lastupdate
    • retireddate
B. Set the Output Format to: %Y-%m-%d
C. Enable Passthrough Nulls, Empties, or Missing
D. Click on “OK”.
3. Add a Clipper to the Workspace
This step retrieves modified features within Dirty Areas. Add a Clipper to the workspace canvas and
A. Connect the Clipper Input port to the AttributeManager (connected to Dirty Areas reader feature type).
B. Connect the Candidate Input port to the DateTimeConverter.
4. Add a Sorter to the Workspace
This step prepares the table in the HTML. Add a Sorter to the workspace canvas and
A. Connect the Inside output port from the Clipper to the input of the Sorter.
5. Add StatisticsCalculator to the Workspace
Add a StatisticsCalculator to the workspace and
A. Connectthe  output of the Sorter to one of the StatisticsCalculator
Repeat Step 5 two more times.
6. Edit StatisticsCalculator Parameter
In the StatisticsCalculator parameter dialog for StatisticsCalculator:
A. Enable Group Processing and set ASSETGROUP for Group By
B. Set Calculation Method to String
C. Specify ASSETGROUP for Attribute and enable Total Count
D.
ASSETTYPE for Attribute and enable Total Count, Numeric Count, and Value Count
E.
Click on “OK”.
In the StatisticsCalculator parameter dialog for StatisticsCalculator_2:
A. Enable Group Processing and set SystemSubnetworkName for Group By
C. Specify SystemSubnetworkName for Attribute and enable Total Count, Numeric Count, and Value Count
D. Click on “OK”.
In the StatisticsCalculator parameter dialog for StatisticsCalculator_3:
A. Enable Group Processing and set lifecyclestatus for Group By
C. Specify lifecyclestatus for Attribute and enable Total Count, Numeric Count, and Value Count
D. Click on “OK”.
7. Add HTMLReportGenerator to the Workspace
Add four HTMLReportGenerator transformers to the workspace and
A. Connect the output of the StatisticsCalculator to the HTMLReportGenerator
B. Connect the output of the StatisticsCalculator_2 to the HTMLReportGenerator_2
C. Connect the output of the StatisticsCalculator_3 to the HTMLReportGenerator_3
D. Connect the output of the Sorter to the HTMLReportGenerator_4
Your workspace should look similar to this:
8. Edit HTMLReportGenerator Parameter
For this tutorial, two pie charts, one bar chart, table, and map will be created
In the HTMLReportGenerator Parameters dialog for HTMLReportGenerator:
A. Create two Header and one Chart (Pie) under Page Contents
B. For the first Header, specify the Text as ‘Report of Utility Network Dirty Area Features’, set the Header Level as H1, and set the Text Alignment as Center
C. For the second Header, specify the Text as ‘Breakdown of Asset Types’, set the Header Level as H2, and set the Text Alignment as Center
D. For the Chart (Pie), set the Label Attribute as ASSETGROUP and set the Data Attribute as ASSETTYPE.total_count
E. Click on “OK”.
In the HTMLReportGenerator Parameters dialog for HTMLReportGenerator_2:
A. Create one Header and one Chart (Pie) under Page Contents
B. For the header, specify the Text as ‘Breakdown of System Subnetwork’, set the Header Level as H2, and set the Text Alignment as Center
C. For the Chart (Pie), set the Label Attribute as SystemSubnetworkname and set the Data Attribute as SystemSubnetworkname.total_count
D. Click on “OK”.
In the HTMLReportGenerator Parameters dialog for HTMLReportGenerator_3:
A. Create one Header and one Chart (Bar) under Page Contents
B. For the Header, specify the Text as ‘Breakdown of Life Cycle Status’, set the Header Level as H2, and set the Text Alignment as Center
C. For the Chart (Bar), set the X Tick Label Attribute as lifecyclestatus and set the Data Attribute as lifecyclestatus.total_count
D. Click on “OK”.
In the HTMLReportGenerator Parameters dialog for HTMLReportGenerator_4:
A. Following the order, create Header, Table, Header, and Map (Esri Leaflet) under Page Contents.
B. For the first Header, specify the Text as ‘Table of Modified Features in Dirty Area’, set the Header Level as H2, and set the Text Alignment as Center
C. Select the following Column Contents and specify the Column Name.
Column Contents  Column Names
ASSETGROUP Asset Group
ASSETTYPE Asset Type
assetid Asset ID
SystemSubnetworkName System Subnetwork
lifecyclestatus Current Status
ownedby Ownership
installdate Installed Date
lastupdate Data Last Updated
updatedby Data Updated by
GLOBALID Global ID
D. For the second Header, specify the Text as ‘Locations of Modified Features within Dirty Areas’, set the Header Level as H2, and set the Text Alignment as Center
E. For the Map (Esri Leaflet), set the Label Attribute as Information
F. Click on “OK”.
9. Add AttributeCreator to the Workspace
Add four AttributeCreator to the workspace to the workspace and
A. Connect the output of the HTMLReportGenerator to the AttributeCreator
B. Connect the output of the HTMLReportGenerator_2 to the AttributeCreator_2
C. Connect the output of the HTMLReportGenerator_3 to the AttributeCreator_3
D. Connect the output of the HTMLReportGenerator_4 to the AttributeCreator_4
10. Edit AttributeCreator Parameters
In the AttributeCreator Parameters dialog:
A. Specify ‘_order’ for Output Attribute
B.
Set the Value to 1
Repeat Step 10 three more times, but set the value to
  • 2 for AttributeCreator_2
  • 3 for AttributeCreator_3
  • 4 for AttributeCreator_4
11. Add a Sorter to the workspace
This step prepares for the order of elements for HTML. Add a Sorter to the workspace canvas and
A. Connect all the AttributeCreators to Sorter_2
12. Edit Sorter Parameters
In the Sorter Parameter dialog:
A. Specify ‘_order’ for Attribute
B. Set Numeric for Alpha/Num
C. Set Ascending for Order
D. Click on “OK”.
Part 3: Consolidating HTML Elements and Writing an HTML File
1. Add an HTMLLayouter to the Workspace
Add an HTMLLayouter to the workspace canvas and
A. Connect the output of Sorter_2 to the HTMLLayouter
2. Edit HTMLLayouter Parameters
In the HTMLLayouter Parameters dialog:
A. Specify the Page Title as ‘Utility Network Dirty Area Dashboard’
3. Add a Writer to the Workspace
Add an HTML writer to the canvas.
In the parameters, set the following:
A. Set the Format as: HTML
B. Specify the file path and name you want to save to by clicking on the ellipsis (next to Dataset).
C. Click on “OK”.
4. Connect the HTMLLayouter to the Writer
Your final workspace should look similar to this:
5. Save and Run the Workspace
Now, save and run the workspace. View the created HTML file.
Your HTML should look similar to this:
Data Attribution
Water Distribution Utility Network Foundation data is copyright 2024 Esri. Licensed under Apache-2.0. Source: ArcGIS Solutions.
