Python Scripted Parameters in FME
Liz Sanderson
Liz Sanderson
This article is part 3 of a 5-part series to help you get started with basic Python and FME. This article covers scripted parameter functionality in Workbench and walks through two example applications that use scripted parameters.
Scripted parameters are useful when you want to set a parameter in FME based on something you derived or calculated from another parameter or parameters. For example, you may want users to select themes or groups of layers and have your script set the individual feature types to read within these groups. For Python scripts, a number of FME variables are available within the fme module, one of which returns a dictionary of FME parameters and their values. For more information, please review the Python and FME Basics introduction article.
Scripted parameters are executed before both Python startup scripts and the translation.
As of FME 2025.2, the term "Published Parameters" has been renamed in both FME Form and FME Flow.
  • In FME Form, "Published Parameters" are now called Visible Parameters and "Private Parameters" are now called Hidden Parameters.
  • In FME Flow, "Published Parameters" are now simply called User Parameters.
This terminology is still in the process of changing, so older versions may still reference "Published Parameters".
Example 1: Scripting Feature Types to Read
Attached workspace: ScriptedParameter1.fmwt.
ScriptedParameter1.fmwt is a good example of scripting the feature types to read parameters based on a user-selected group. The workspace template, ScriptedParameter1.fmwt, is included within the scriptedparameters-workspaces-2021.zip file (see the Files section).
This workspace selectively reads feature types using a scripted parameter. Enable the Prompt for User Parameters option before running the workspace to see the user parameters. A Translation Parameters window will appear. Click on the ellipsis in the window to bring up the Select ‘Layers’ Items window. Notice that the layers you can choose from are groups:
  • Walking and Biking
  • All Methods
  • Rapid Transit
Choose "Walking and Biking" and run the workspace. Notice the workspace reads both the Bikeways and the PublicStreets feature types.
Let’s look at the scripted parameter that tells FME to return both feature types to the Feature Types to Read parameter when you choose Walking and Biking. In the Navigator pane, expand User Parameters > Private Parameters, and you will see a Python script parameter called feature_types_to_read. This parameter is linked to the reader's Feature Types to Read parameter in the workspace. Whatever value the AutoCAD reader uses, the script determines which feature type to read.
Go back to the scripted parameter, double-click on it, and click the ellipsis to open the editor. Here is the script used inside:
import fme
featureTypes = ''
if fme.macroValues['layers'].find('Walking and Biking') != -1:
    featureTypes += 'PublicStreets Bikeways '
if fme.macroValues['layers'].find('Rapid Transit') != -1:
    featureTypes += 'RapidTransitLine RapidTransitStations '
if fme.macroValues['layers'].find('All Methods') != -1:
    featureTypes += 'PublicStreets Bikeways RapidTransitLine RapidTransitStations '
#Debug
#print(featureTypes)
return featureTypes
You can see that we have a series of if statements that find out which layer the user chose using the fme.macroValues[] dictionary and then sets the value of featureTypes, which will be returned. The last line is the most important, as this is where we "return" the actual value of the scripted parameter with the statement:
return featureTypes
This return statement must always exist in a Python-scripted parameter because it is here that the parameter value is given to FME. Also, notice the commented-out print function. You can use the print function to help you debug your scripts by returning variable values to the Translation Log pane. For more on logging with Python, see this article: Logging with Python Scripts.
Example 2: Unique Output Dataset Names with Scripted Parameters
Attached workspace: ScriptedParameter2.fmwt
When writing files, you may want to ensure that your output is uniquely named. One way to do this is to use a scripted parameter to append the date and time to the output dataset name. The workspace ScriptedParameter2.fmwt accepts a user parameter for the output dataset name, and a private scripted parameter appends a unique value (date and time) to the user parameter value. The workspace itself identifies points (such as drinking fountains) that fall within park polygons and outputs a CSV file.
Open the workspace and ensure that Prompt for User Parameters (found under the Run menu) is enabled. Run the workspace, and the Translation Parameters window will appear. Click OK to accept the default output dataset name.
Take a look at the Translation Log pane once the workspace has finished running. Under the Features Written Summary at the end of the log, you will see the name of the output CSV file written. It will be in the following format: <fileName>_<YYYYMMDD>_<HHMMSS>, where <fileName> is the value of the user parameter (test12 in the sample workspace), <YYYYMMDD> is the current date, and <HHMMSS> is the start time of the translation.
Go to the Navigator > User Parameters > Private Parameters > nameWithTime and double-click to open the script editor. Here is the script used inside:
# Import fme module and datetime.datetime class
import fme
from datetime import datetime
# Get the value of the user parameter
OutFileName = fme.macroValues['OutFileName']
# Use the now() method to get the current date and time
# Format date as YYYYMMDD_HHMMSS with strftime method
curTime = datetime.now().strftime("%Y%m%d_%H%M%S")
# Concatenate the user parameter, an underscore, date time
OutFileName += f'_{curTime}'
# Return unique file name which becomes the value of the scripted parameter
# This scripted parameter is linked to the destination dataset name
return OutFileName
The script gets the value of the user parameter using the fme.macroValues[] dictionary and the current date and time by calling the datetime.now() function. It concatenates the datetime value to the user-defined filename and returns the unique value (fileName_YYYYMMDD_HHMMSS) to the writer with the return statement. Remember, a scripted parameter must always include a return statement.
Adding the date and time to an output file name is also possible without using scripted Python parameters (e.g., by using the DateTimeNow() function that is available in the text editor).
For more information on the Date/Time functions in Workbench, please see the help documentation: Date/Time Functions.
Documentation
For using FME Objects in Python, you can find complete documentation of the Python FME Objects API here: FME Objects Python API.
