Symptom
When you try to start an FME Server Windows Service, you receive an Error 1067 and the service will not start.
Error 1067: The process terminated unexpectedly.
Cause
Common issues that cause the 1067 error:Permissions
On Windows OS, the User or Service Account configured to 'Logon As' for the FME Server Service does not have correct permissions.
SSL Configuration [in case its the FME server Web Application Service that won't start]
- Syntax errors in the XML files while configuring FME Server for HTTPS.
- Passwords contain invalid characters.
Resolutions
PermissionsTry changing the account that is used to start the Windows Service. The account needs to have permission to read and write into the FME Server System Share.
- Ensure that each configuration file (server.xml, web.xml, context.xml) contains valid XML syntax. This can be done quickly in a text editor or online validation tool.
- When removing or commenting out sections of the configuration files, ensure that the entire section is contained.
- If the certificate requires a password, make sure all special characters have been escaped using XML entity replacements .
If this does not solve your issue, then please contact the Safe Support Team.
Comments
0 comments
