Getting Started with the Split-Merge Block
Liz Sanderson
Liz Sanderson
Automations in FME Flow offer a wide range of options for building enterprise integrations that solve your data challenges. The capabilities of automations can be stretched far beyond basic trigger-action workflows. You can take your workflows to the next level with the Automation Writer to create data-driven workflows that scale up jobs based on incoming features rather than events. We’ve expanded the power of automations by introducing the Split-Merge Block to support parallel job processing and improve data-driven workflow functionality.
Prerequisites
Please note that this is an advanced Automation authoring article. You need a working knowledge of the Automation Writer and output keys. For a quick introduction, please read the Automation Writer documentation, Output Attributes documentation, and Building Integrations with the FME Flow Automation Writer.
What Are Data-Driven Automations?
Before we explore the split-merge block, we need to understand data-driven automations. In a simple automation, an event trigger or an action succeeding/failing runs the next action once. With the Automation writer, you can output features from a workspace, run downstream actions on a per-feature basis, and dynamically fill in parameter values based on each feature’s attribute values. Routing N features to an action scales the number of times the workspace/external action runs to N times. However, in many scenarios, actions further downstream only need to be run once, such as sending a single email notification when an automation is complete. How do you deal with this challenge?
Workflows that incorporate the Automation Writer need a way to downscale or merge the jobs so that downstream actions aren’t run excessively. The Merge Action is meant for this purpose, but it’s only compatible with event messages (Success/Failure) and not Automation Writer messages. This is where the split-merge block comes into play.
What Is The Split-Merge Block?
The split-merge block looks like a bookmark: it encircles a set of workspace actions, with one input port for incoming messages and two outgoing ports for successes/failures. You can add one to the canvas by opening the component menu and selecting the Split-Merge Block iconIcon.png.
To solve the challenge in the previous section, the block treats contained workspaces as a single event and outputs one message. This message includes only information from the last job run inside the block. The split-merge block is primarily used with workflows that incorporate the Automation writer because a basic chain of workspaces won’t scale beyond one job per workspace.
It can be difficult to visualize how many messages pass through an automation, so this article adds annotations to screenshots to show how many messages move between components. The annotation color indicates how different messages and components control how many times other actions run.
Why Should You Use the Split-Merge Block?
The main advantages of the Split-Merge Block include:
  • Running a group of jobs in parallel across multiple FME Flow Engines.
  • Treating the success/failure of a group of jobs as a single event.
  • Downscaling event messages in data-driven automations to run downstream actions without excessive work.
Many users tend to create one large workspace to cover every step in the translation; this is advantageous because:
  • It’s easier to visualize the complete workflow.
  • Feature caching makes it easy to build.
However, there are major disadvantages:
  • It’s difficult to hand over the workspace to other users unless it is well documented.
  • One large workspace underutilizes hardware resources.
By breaking workspaces into smaller, distributable, manageable pieces with the Automation Writer and Split-Merge Block, you can address these challenges and add downstream functionality to your workflows. Now let’s walk through some use cases with the Split-Merge Block.
Basic Use Cases
Run a Chain of Jobs in Parallel
A GIS Analyst wants to quickly process large groups of spatially related data across multiple FME Flow engines and automatically send a single email to themselves once all of the jobs are finished. The single state has 5 counties and 10 blocks per county, which scales up Process Block to 50 jobs. After these jobs run successfully, Downstream Work runs once, and an email is sent.
The split-merge block only releases a failure message if the job originates from a workspace action that’s connected to the block’s failure port. In this case, the split-merge block will only return a failure if at least one job fails for the Process Block workflow.
A different configuration would be receiving an email notification when each county is processed. This will run five groups of jobs for each county from Process State.
Run Parallel Workspaces
An IT department wants to automatically update internal databases and systems with invoices from their finance department. When everything is done, they want to send a REST API request to an internal application. An incoming invoice file is split into individual items and triggers two parallel processes: one to handle individual invoice items and another to update the databases. These jobs run faster in parallel across multiple engines. The split-merge block downscales the work into a single output message so that only one REST API request is made in the end.
Run a Dynamic Set of Workspaces in Parallel
A quality analyst wants to run a set of validation workspaces against a new dataset and generate a single report when all the tests run successfully. The Testsuite Control workspace reads a test suite spreadsheet to determine which workspaces to run. It outputs a set of features from the Automation writer to dynamically tell the Dynamic Workspace action which workspaces to run. Whenever the test suite spreadsheet is edited, FME Flow authors don’t need to manually add/remove test suite workspaces from the automation. If any of the tests fail, an email is sent to the QA team.
For a guide on Dynamic Workspaces, please read our article on Dynamic Workspaces: Data Driven Parallel Processing
Advanced Functionality
Connect to Actions Outside the Split-Merge Block
It’s possible to send event and Automation writer messages out of a split-merge block, but you cannot send messages into a block that originated from outside. You can use outer connections instead of, or in addition to, the block's success and failure ports.
Tip: automations don’t have feature caching, so make use of the “Log a Message" action. This helps with troubleshooting and lets you see exactly what message content is passed between workspaces.
Nested Split-Merge Blocks
Any number of blocks can be nested within each other. This is particularly useful when you want to gradually scale down jobs or external actions. For example, consider the scenario below, where a nested block is required to make the Downstream Work workspace run five times while sending only |one emil at the end.
Chained Split-Merge Blocks
Automations can work with chains of split-merge blocks. However, you need an action or external action connecting the two because the output of one split-merge block cannot directly connect to the input of another. Chained split-merge blocks are useful when you have multiple automations to run in sequence and want to perform an action after the entire workflow completes.
 If you need to chain two split-merge blocks without running a workspace or external action, use the log action.
Parallel Split-Merge Blocks
It is also possible to run multiple split-merge blocks in parallel. The next downstream component should be a merge action. This way, the automation will wait for all blocks to finish before processing the rest of the workflow.
Conclusion
For a detailed dive into the split-merge block, read the next article, Understanding the Split-Merge Block | Troubleshooting & FAQs, to learn about workflow design considerations, output port behavior, and troubleshooting tips.
Additional Resources
Getting Started with Automations
Building Integrations with the FME Server Automation Writer
Job Orchestration with Automations
Getting Started with Enterprise Integration Patterns
