Workspace Fails on FME Flow: FME Version Incompatibility
Liz Sanderson
Liz Sanderson
Symptom
An FME workspace runs correctly on FME Workbench but fails to complete on FME Flow.
Errors encountered may look like:
  "This FME edition does not recognize the 'RoutingFactory' factory."
or
  The clause 'FACTORY_NAME AttributeCreator_5 ATTRSET_PROPAGATE_MISSING YES' within 'FACTORY_DEF * AttrSetFactory FACTORY_NAME AttributeCreator_5 ATTRSET_PROPAGATE_MISSING YES INPUT FEATURE_TYPE TestFilter_5_UpdateRecord ATTR fme_db_operation Update OUTPUT OUTPUT FEATURE_TYPE AttributeCreator_5_OUTPUT' is incorrect. It must look like: FACTORY_NAME
Cause
This error usually occurs when a workspace has been created or edited in a newer version of FME and then run on an older version of FME Flow. This happens because new capabilities have been added to a transformer, which older versions of FME Flow do not understand. In general, FME does not support forward compatibility, although it may work in some cases.
Resolution
You may need to edit or rebuild the workspace in an FME Form version that matches the FME Flow version. Alternatively, you can update the FME Flow engines to the latest version.
