FME Server with IIS/Tomcat integration: 401 Error
Liz Sanderson
Liz Sanderson
FME Version
Symptom
When running FME Server with IIS/Tomcat integration, accessing the FME Server via the IIS integration returns a 401 Error. Accessing the Server directly via port 8080 causes no problems.
Cause
The error pages settings are incorrect. By default, the error pages are configured to serve detailed errors for local requests and custom error pages for remote requests. Serving up custom error pages causes the problem.
Resolution
In Internet Information Services (IIS) Manager, go to the feature Error Pages for the website FME Server is installed on. Set the Error Responses to Detailed Errors for each status code.
You should instantly be able to access FME Server from within the web browser.
Comments
0 comments
