Creating a New FME Transformer
Liz Sanderson
Liz Sanderson
You can find a full list of FME transformers in our documentation; additional transformers are available in the FME Hub. If Safe Software doesn't support the transformation you need, you can extend FME's functionality in several ways.
  1. FME Transformer Designer
  2. Create a Custom Transformer
  3. Python or Tcl Scripts
  4. Use the FME Plug-in SDK
Options for Extending the Functionality of FME
New for FME 2023.0, the FME Transformer Designer is included with an FME Form installation. This application lets you develop FME Packages using Python. See the documentation for more information on how to get started.
You can use any combination of existing readers and transformers to create a custom transformer using FME Workbench. If you know a third-party command-line tool that processes data in the way you require, you can create a custom transformer that leverages the tool.
You can use Python or Tcl* scripts within an FME Workspace via startup/shutdown scripts and the following transformers:
As of FME 2024.0, Tcl will no longer be available in FME. Please use FME 2023.2 or earlier, or use a different method to create a new transformer.
Developers can use the FME Plug-in SDK to develop a new custom transformer. Many of our partners use the SDK to introduce new transformers to FME.
The Plug-in SDK includes comprehensive documentation, samples, test cases, and build files to help you enhance a custom transformer. For information about getting started with the SDK, please see Developing a New Transformer Using the FME Plug-in SDK
Submit an Idea
A fifth option if you don't wish to create the transformer yourself is to submit an Idea for the transformer to the FME Community or reach out to one of our Partners.
