Cannot read Oracle Spatial - bad geometries
Liz Sanderson
Liz Sanderson
FME Version
Symptom
FME Oracle Spatial reader fails with an error message like:
 ERROR |Error converting Oracle Spatial object geometry type to an integer: message was `An error occurred converting an Oracle OCINumber object to an integer: `OCI-22060: argument [2] is an invalid or uninitialized number
Cause
Probable cause is an invalid geometry in the Oracle Spatial column
Resolution
Validate the Oracle geometry:
      select sdo_geom.validate_geometry (<tablename>, geom, 0.5) from <tablename>
You may need to change "geom" to match the name of the geometry column.
Comments
0 comments
