FME Hub Transformer Deprecations
Sienna Emery
Sienna Emery
Over time, some transformers on FME Hub are deprecated due to changes in underlying libraries, enhancements in functionality, renaming for clarity, or because they have been integrated directly into FME. This article provides a list of deprecated custom transformers created by Safe Software, including when they were deprecated and their recommended replacements. If you were using one of these transformers, refer to the replacement details to ensure a smooth transition in your workflows. This list is only for Safe Software created items on FME Hub. For a list of deprecated built-in features, see FME Deprecations.
If a workspace is currently using a deprecated transformer, it should still work as long as the underlying library still works. To install a deprecated transformer, it can be downloaded directly from the FME Hub, see the documentation.
Web services do not have versions, if they have been removed from FME Hub, you will not see them in any version of FME.
Deprecated FME Hub Transformers
Deprecated FME Hub Transformer Version Deprecated Replacement
NoFeaturesTester FME 2026.2.0.0 (Build 26333) NoFeaturesTester
CityworksCaseCreator FME 2026.2.0.0 (Build 26333) TrimbleUnityConnector
CityworksCaseTaskAdder
CityworksCaseTaskUpdater
CityworksCloseDelete
CityworksConnector
CityworksContractorCosts
CityworksEquipmentCosts
CityworksLabourCosts
CityworksMaterialCosts
CityworksWorkOrderUpdater
InspectionCreator
InspectionCreatorFromInsp
InspectionCreatorFromSR
InspectionCreatorFromWO
ServiceRequestCreator
WorkOrderAttachmentAdder
WorkOrderCanceler
WorkOrderCreator
WorkOrderCreatorFromInsp
WorkOrderCreatorFromSR
WorkOrderCreatorFromWO
EthereumConnector  FME 2025.2 (Build 25810) None
AdvancedSorter FME 2025.1.2.0 (Build 25630) Sorter
ArcGISOnlineMetadataFetcher FME 2024.2.1.0 (Build 24801) ArcGISOnlineConnector
ArcGISOnlineMetadataOverwriter FME 2024.2.1.0 (Build 24801) ArcGISOnlineConnector
CityworksEmployeeCosts FME 2024.1.0.0 (Build 24612) CityworksLabourCosts
FreeGeoIPCalculator FME 2024.0.0.0 (Build 24187) Geocoder
littleBitsConnector FME 2024.0.0.0 (Build 24187) None
FlightStatistics FME 2024.0.0.0 (Build 24187) None
InclusiveSampler FME 2023.0.0.3 (Build 23319) AdvancedSampler
JSONEmptyElementDeleter FME 2023.0.0.3 (Build 23319) None
StandardDistanceEllipseCreator FME 2023.0.0.3 (Build 23319) DistanceDeviationEllipseCreator
FMECloudBalanceChecker FME 2023.0.0.0 (Build 23283) FMEFlowHostedBalanceChecker
FMECloudInstanceController FME 2023.0.0.0 (Build 23283) FMEFlowHostedInstanceController
FMECloudInstanceLauncher FME 2023.0.0.0 (Build 23283) FMEFlowHostedInstanceLauncher
FMECloudInstanceLister FME 2023.0.0.0 (Build 23283) FMEFlowHostedInstanceLister
FMEServerEmailGenerator FME 2023.0.0.0 (Build 23283) FMEFlowEmailGenerator
FMEServerURLSplitter FME 2023.0.0.0 (Build 23283) FMEFlowURLSplitter
ArcGISOnlineWebhookDecoder FME 2022.1.1.0 (Build 22623) Use FME Flow 2021+
ControlledNullSorter FME 2022.1.0.0 (Build 22618) AdvancedSorter
PreciselyGeocoder FME 2022.1.0.0 (Build 22618) Geocoder
SurfaceClipper FME 2022.1.0.0 (Build 22607) Clipper
PythonModuleInstaller FME 2022.0.0.0 (Build 22271) None
SolidDissolver FME 2022.0.0.0 (Build 22167) SolidDissolver - Shipped
SchemaSetter FME 2021.2.2.0 (Build 21806) SchemaScanner
AddressStreetSuffixAbbreviationExpander FME 2021.1.0.0 (Build 21549) AddressAbbreviationValidator
SpatialSorter FME 2021.0.0.0 (Build 21258) SpatialSorter - Shipped
SkyWatchConnector FME 2020.1.0.1 (Build 20596) EarthCacheConnector
DateCalculator FME 2019.2.1.0 (Build 19813) DateTimeCalculator
DateConverter FME 2019.2.1.0 (Build 19813) DateTimeConverter
DateDifferenceCalculator FME 2019.2.1.0 (Build 19813) DateTimeCalculator
DistanceMarker_2013 FME 2019.1.0.0 (Build 19608) DistanceMarker
AzureBlobUploader FME 2019.0.1.0 (Build 19253) AzureBlobStorageConnector
UpdateDetector FME 2019.0.0.0 (Build 19034) ChangeDetector
AzimuthCalculator FME 2018.0.0.0 (Build 18284) HorizontalAngleCalculator
PointCloudZClipper FME 2017.1.1.0 (Build 17650) PointCloudFilter
RasterSpikeFinder_2013 FME 2017.0.0.0 (Build 17245) RasterSpikeFinder
GoogleGeocoder FME 2017.0.0.0 (Build 17228) Geocoder
WordWrapper FME 2016.1.3.0 (Build 16709) TextWrapper
SOAPSender FME 2016.1.2.1 (Build 16674) HTTPCaller
CollinearSliversRemover FME 2016.1.0.1 (Build 16494) SpikeRemover
DynamoDBQuerier FME 2016.1.0.1 (Build 16494) AmazonDynamo Reader
JpegGPSPointReplacer FME 2016.1.0.1 (Build 16494) PhotoCoordinateExtractor
PythonEmailer FME 2016.1.0.1 (Build 16494) Emailer
TCLEmailer FME 2016.1.0.1 (Build 16494) Emailer
CentredLabelAdder FME 2016.1.0.0 (Build 16492) CenteredLabelAdder
GeonamesGeocoder_2013 FME 2016.1.0.0 (Build 16492) Geocoder
DonutHoleFilter_2013 FME 2016.0.1.1 (Build 16177) DonutHoleFilter
ElevationIntersector FME 2014 (Build 14235) Intersector
FMECloudAvailableVersions FME 2014 (Build 14235) None
LoopFilter FME 2014 (Build 14235) ClosedCurveFilter
StringMultiSearcher FME 2014 (Build 14235) StringSearcher
UnconditionalFeatureMerger FME 2014 (Build 14235) FeatureMerger
RandomizedSampler FME 2014 (Build 14235) Sampler
CentreOfGravityAccumulator FME 2014 (Build 14230) CenterOfGravityAccumulator
FileExistanceChecker FME 2014 (Build 14230) FileExistenceChecker
GeographicBufferer FME 2014 (Build 14230) Bufferer
MeasureInterpolator_2013 FME 2014 (Build 14230) MeasureInterpolator
NullAttributeRemover FME 2014 (Build 14195) NullAttributeMapper
AttributePacker FME 2013 SP1 (Build 13450) Aggregator
IterativeSnipper_2013 FME 2013 SP1 (Build 13450) IterativeSnipper
RegularExpressionMatcher FME 2013 SP1 (Build 13450) StringSearcher
VertexCounter FME 2012 SP3 (Build 12258) VertexCounter - Shipped
