FME Version
Symptom
When reading a ESRI File Geodatabase using the File Geodatabase API the following Error occurs: Geodatabase Error (-2147220965): This release of the GeoDatabase is either invalid or out of date.
Cause
This error is produced when reading older versions of ESRI File Geodatabase. Only version 10 or newer File Geodatabases are supported by the File Geodatabase API.
Resolution
Only version 10 or newer File Geodatabases are supported by the File Geodatabase API. Upgrade the Geodatabase using a newer version of ArcCatalog (Right Click > Properties > Upgrade Status).
Comments
0 comments
