Purging FME Flow Log Files
Liz Sanderson
Liz Sanderson
Considerations
FME Flow (formerly FME Server) generates log files for every workspace run and system component restart. Over time, these logs can accumulate and take up significant disk space, particularly when using real-time services like the KML network link service.
Why This Happens
  • Each workspace execution in FME Flow creates a log file
  • System components generate logs when restarted
  • Some services, like real-time processing, produce a higher volume of logs
How to Manage It
To prevent excessive log accumulation, use the System Cleanup tools under Admin > System Configuration.
Here, you can:
