Useful commands for FME Flow for Docker
Liz Sanderson
Liz Sanderson
This article covers some useful commands for FME Flow for Docker.
These commands will primarily be for Docker Compose, a tool for defining and running multi-container Docker applications (FME Flow). For more information or a full reference to the Docker Compose CLI, please refer to the official documentation.
The FME Flow Administrator's Guide also has documentation Deploying FME Flow with Docker Compose.
All these commands should be run in the same directory as the docker-compose.yml file, or reference the docker-compose.yml file you want to use. If your docker-compose.yml has a different name, or is in another location, use the -f flag to reference the correct file:
docker compose -f /Users/YourName/Docker/docker-compose-2021.yaml up -d
Managing FME Flow
Docker Compose and Starting FME Flow
To start FME Flow or apply changes to the Docker Compose file, such as editing environment variables, you will need to use the up command.  We start FME Flow in detached mode with the -d flag. This runs containers in the background and will print the new container names.
docker compose up -d
Services
The different FME Flow components are separated into named services. It is useful to know what the names of the services are for the different Docker Compose commands.
  • fmeflowcore - The core FME Flow container
  • fmeflowwebsocket - The server for WebSocket connections
  • fmeflowweb - The web front end container
  • fmeflowdb - The backend database for FME Flow
  • fmeflowengine - The FME engines that accept jobs
  • fmeflowqueue - The FME Flow queue managing the jobs
  • nginx - Reverse proxy for FME Flow; receives all web traffic and forwards it to the right container
You can stop, start, or restart a service. The stop command stops running containers without removing them.
docker compose start <service>
docker compose stop <service>
docker compose restart <service>
To kill a service, use the kill command.
docker compose kill <service>
To remove a stopped container. The next time you start them new instances of the containers will be created:
docker compose rm <service>
Engines
By default, this deployment starts with one engine, but with Docker Compose, it is easy to scale. The “2” in the below command can go as high as you like as long as your license supports a number of engines you scale to.
docker compose up --scale fmeflowengine=4
For more information, please refer to this article: FME Flow and Docker - Managing Engines and Queues
 Upgrade to a newer version of FME Flow
Create a backup of FME Flow. Download the backup file to a location outside of the FME Flow System Share; otherwise, you will lose the backup file.
Stop and remove containers. The -v flag will also remove named volumes, which removes the FME Flow System Share.
docker compose down -v
Download the Docker Compose file for your desired version of FME Flow. Docker Compose files are available by version here.
Start FME Flow. We start FME Flow in detached mode with the -d flag. This runs containers in the background and prints the new container names.
Restore the backup of FME Flow.
Removing FME Flow
To stop and remove all containers, use the down command:
docker compose down
To remove all named volumes (FME Flow System Share) at the same time, use the -v flag:
Troubleshooting
Here are a few of the most common commands that can be helpful when troubleshooting an FME Flow on Docker deployment gone wrong.
View containers:
To show all running containers:
docker ps
To show all containers (including stopped), include the -a flag.
docker ps -a
​​​​View container logs:
docker logs <container>
Run a command inside a container:
docker exec -it <container> /bin/bash
This command opens an interactive (-i) pseudo-terminal (-t) to issue commands within a container.
Show disk usage:
docker system df
Remove unused data:
docker system prune
This command will remove all unused containers, networks, images (both dangling and unreferenced), and optionally, volumes.
Display running processes in a container:
docker top <container>
To do this for the full FME Flow deployment, use Docker Compose:
docker compose top
Manage Docker images:
docker image
