Error truncating geodatabase table (Oracle errors ORA-29859 ORA-06512)
Liz Sanderson
Liz Sanderson
FME Version
Symptom
I receive the following error when trying to truncate a geodatabase table (SDE on Oracle):
 An error occured while trying to truncate table/feature class `table. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {Underlying DBMS error[ORA-29859: error occurred in the execution of ODCIINDEXTRUNCATE routine ORA-03291: Invalid truncate option - missing STORAGE keyword ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1681 ]}. The error will be ignored
Cause
This is likely an issue caused by missing spatial reference information on the table.
Resolution
Load the table again with a spatial reference (or add one to the table). Subsequent truncates should work.
Comments
0 comments
