Command Line Installation of FME Form
Liz Sanderson
Liz Sanderson
Overview
Installing FME from a command line isn't something you would want (or need) to do in everyday use. However, it is very useful when you wish to install FME either 'silently' or remotely. Our documentation on Installing FME Form from the Windows Command Prompt contains more information and examples.
Installing FME this way is very much at your own risk. Not that there are problems with the process—just the potential to introduce errors into FME if you get it wrong.
For instructions on how to perform a silent install of FME Flow, please see the following documentation:
Linux FME Flow Installation Checklist provides an additional guide and suggestions for installing FME Flow on Linux, including information on silent installs.
Preparation
A silent installation will not prompt you to uninstall your previous FME if it is located in the same folder. We strongly recommend uninstalling your previous FME before silently installing another into the same folder.
Command Line Switches (Flags)
There are several switches you can pass to msiexec, the program that installs an MSI file. You can view all switches by opening a command window, typing "msiexec", and pressing the "Enter" key. Here are a few common ones:
Listed below are examples of the switches and an explanation of what each does
Switch
  • Explanation
/i <installFile.msi>
  • Install MSI file. This tells msiexec to install the package specified by <installFile.msi> on your computer.
/q[n|b]
  • Quiet mode. If /qb is specified, a progress bar dialog will be displayed, but there is no user interaction. If /qn is specified, no GUI is displayed.
/x <installFile.msi>
  • Uninstall <installFile.msi> if it has been installed on your system.
/l*v <logfile>
  • Enable verbose logging of the installation to <logfile>
Parameter File Directives
Directives are specified on the command line after the parameters above, in the following format:
<directive name>=<directive value>
If installing with the /q switch, the directive INSTALLLEVEL=3 MUST be specified for the installation to work correctly.
Installation Directory Directives
By default, the installer places files in several locations. These directives allow you to override those locations as needed. All directives need to be followed by an equal sign (=) and then the full path. See examples below.
Below are examples of directives and what each of them does
Directive
  • Explanation
INSTALLDIR
  • Indicates the full path location of the main installation directory. If the directory does not exist, it will be created. Spaces are OK on the path as long as the path is quoted.
    • The default is C:\Program Files\FME
Installer Behavior Directives
The installer's runtime behavior can be changed via these directives.
Directive (in bold)
  • Explanation
ENABLE_SOUNDEVENTS
  • Set up sound events.
    • Allowed values are yes and no. Default is yes.
CHECK_ADMIN_RIGHTS
  • Check whether the user installing FME has admin privileges.
ENABLE_SHORTCUTS
  • Create shortcuts in the Windows Start Menu.
ENABLE_FILETYPE_REGISTRATION
  • Register FME applications to view, open, etc., FME and GIS data files.
ENABLE_PATH_UPDATE
  • Allows the installer to update the 'PATH' environment variable.
ENABLE_STANDARD_EXE_INSTALLATION
  • Install all the standard FME executables (viewer, workbench, etc).
ENABLE_LICENSE_COPY
  • Allows the installer to search for old license files and copy them into the current install folder if present.
ENABLE_POST_INSTALL_TASKS
  • Controls whether the license wizard runs after the installer completes. See also FMEREG_CMDLINE.
ENABLE_ZERO_SIDE_EFFECT
  • Sets the following options to "no":
    • ENABLE_SOUNDEVENTS, CHECK_ADMIN_RIGHTS,INSTALL_SYSTEM_DLLS,
    • ENABLE_SHORTCUTS,ENABLE_FILETYPE_REGISTRATION,
    • ENABLE_POST_INSTALL_TASKS,ENABLE_PATH_UPDATE,ENABLE_LICENSE_COPY
Allowed values are yes and no. Default is no.
ENABLE_NAD83_NAD27_DATUMSHIFTS
  • Controls whether the implicit NAD27-to-NAD83 Datum Transformation is set to USA or CANADA.
    • Allowed values are Yes, No, and None.
      • Default is No, which sets it to USA
      • Yes, it's CANADA only
      • None will disable it; the workspace will error when trying to use that shift
REPORTSTATISTICS
  • Controls whether the statistics about formats and transformers are sent to Safe Software.
    • Allowed values are Yes and No. Default is Yes.
File Installation Directives
Some of the files installed by the installer can be omitted via these directives.
Listed below are examples of the directives that can omit installation files and an explanation of what each does
Directive
  • Explanation
INSTALL_SYSTEM_DLLS
  • Update older system DLLs as needed, and run the Microsoft Visual Studio C++ Runtime Installer
If set to 'no', the user is responsible for manually running the C++ Runtime installer and ensuring that atl.dll and atl71.dll are installed on the target system. This option is not recommended and may result in non-functional FME installations.
INSTALL_THIRDPARTY
  • Install Application Extenders
Enabling is controlled by the FME Administrator.
INSTALL_FMEOBJECTS
  • Install FME Objects DLLs and other components
INSTALL_GALLERY
  • Install the gallery directory
INSTALL_HELP
  • Install the help directory
INSTALL_HELP_DLL
  • Install the help DLLs
INSTALL_METAFILE
  • Install the metafile directory
INSTALL_PLUGINBUILDER
  • Install the pluginbuilder directory
INSTALL_REPROJECT
  • Install the Reproject directory
INSTALL_TCL
  • Install the Tcl directory
INSTALL_WORKBENCH_EXE
  • Install the workbench application
INSTALL_FME_EXE
  • Install the fmeapplication
INSTALL_FMEADMIN_EXE
  • Install the FME Administrator application
INSTALL_FMEVIEW_EXE
  • Install the FME viewer application
INSTALL_FMEGUI_EXE
  • Install the FME Universal Translator GUI application
INSTALL_FMEREG_EXE
  • Install the FME license wizard application
INSTALL_WHATSNEW
  • Install the what's new/great text files
INSTALL_FMECOMUTIL_DLL
  • Install the fmecomutil DLL
INSTALL_FME_SHELLEXT_DLL
  • Install the FME shell extension DLL
INSTALL_SPATIAL_ASSISTANT_EXE
  • Install spatialassistant.exe
INSTALL_FMEGEOS_DLL
  • Install geos_fme.dll
Licensing FME Form from the Windows Command Prompt
You can activate an FME installation for a floating license using the following syntax: fmelicensingassistant_cmd --floating <server>[:<port>] <license type>
To get the proper values for <license type>, run:
fmelicensingassistant_cmd.exe --query <server>[:<port>]
Example
fmelicensingassistant_cmd.exe --query testserver
 msiexec /i fmeinstaller.msi INSTALLDIR="C:\Programs\FMEDirectory"
This will throw up the installation GUI, but the default installation directory will be replaced with C:\Programs\FMEDirectory.
 msiexec /i fmeinstaller.msi /qn INSTALLLEVEL=3
This will install in the installer's default directory, but it will not display the GUI during installation.
 msiexec /i fmeinstaller.msi /qb INSTALLLEVEL=3 INSTALLDIR="C:\Programs\FMEDirectory" ENABLE_SHORTCUTS=no
This will silently install into C:\Programs\FMEDirectory and will not install any shortcuts.
 msiexec /i fmeinstaller.msi /l*v logfile.txt
This will run the installer normally, but will log everything to logfile.txt.
Notes
When the installer runs silently from the command line with the /qn option, it appears to return immediately, with the installation running in the background. It is always a good idea to enable logging when installing silently so you can check for errors.
The parameter INSTALLLEVEL=3 must always be specified when installing silently from the command line.
"Microsoft SQL Server 2012 Native Client" and "Microsoft System CLR Types for SQL Server 2012 (x64)" are not automatically installed with the silent installer. These can be installed afterward from the FME installation directory:
msiexec /i sqlncli.msi /qb
msiexec /i SQLSysClrTypes.msi /qb
