Working with Oracle spatial tables from within the Esri ArcGIS products
Liz Sanderson
Liz Sanderson
In order for the ArcGIS Interoperability extension to successfully display an Oracle Spatial table, the table must have a spatial index. You may need to contact your Oracle database administrator to have the spatial index added. The following example Oracle SQL command will create a spatial index for a table (for the geometry column named 'geom'):
 CREATE INDEX my_index ON my_table(geom) INDEXTYPE IS MDSYS.SPATIAL_INDEX;
In order for the ArcGIS Interoperability extension to successfully identify individual features (and show them in a table view), the table must have an integer index. Ensure that the database table has an indexed column with the following properties:
  • The indexed column must be an integer type (with unsigned 32 bit values).
  • The indexed column must require unique values.
  • The indexed column must not allow null values.
If you already have a column in the table with unique integer values, then you can use the following example Oracle SQL commands to make the column indexed and not null:
 ALTER TABLE my_table ADD UNIQUE (my_old_id); ALTER TABLE my_table MODIFY (my_old_id NOT NULL);
If you do not have a unique integer column in the table, then you need to create a new column and set the values with unique integers. The following example Oracle SQL commands will create a new indexed column:
 ALTER TABLE my_table ADD my_new_id INTEGER UNIQUE; UPDATE my_table SET my_new_id = ROWNUM; ALTER TABLE my_table MODIFY (my_new_id NOT NULL);
