Error while performing SE_stream_execute.:SDE_ERROR_CODE(-51) Numeric value out of range
Liz Sanderson
Liz Sanderson
FME Version
Symptom
The following error is encountered when reading from an Enterprise Geodatabase sitting on SQL Server using the GEODATABASE_SDE reader.
Error while performing SE_stream_execute.:SDE_ERROR_CODE(-51) Underlying DBMS error. SDE_EXT_ERROR(22003) SDE_ERROR_MSG1([Microsoft][SQL Server Native Client 10.0]Numeric value out of range) SDE_EXT_ERROR_MSG2()
This error can also be displayed when
  • Selecting features with a WHERE clause
  • Writing to a new feature class that includes building the feature class
Cause
The problem is with the SQL Server client. There is further information here in the Esri forums.
Resolution
Depending on your version of FME the problem can be resolved by reinstalling the 32 bit or 64 bit version of the SQL Server Native Client.
See this article for information on other SQL Server client error messages and links to the SQL Server Native Client download sites.
Comments
0 comments
