Unable to Access Background Maps in FME Data Inspector
Liz Sanderson
Liz Sanderson
Why can't I access Background Maps in Data Inspector?
Answer
Your firewall or proxy server may be blocking background map URLs. The best way to check if a proxy server or firewall is blocking URLs is to get a log from Data Inspector. In Data Inspector, with Background Maps on, you may need to try refreshing the map by zooming out before getting any error messages.
You may see the following error messages:
“Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections.”
Or
“... Unable to access network resources, please check your network configuration. Attempted to access... A fatal error has occurred"
Please speak to your IT Team to add Background Maps URLs to the proxy server exception list.
Please note that a number of proprietary background maps (Esri ArcGIS Online Map Service, Google Maps Engine Map Service, Microsoft Bing Maps, MapBox Web Map Tile Server, MapQuest Web Map Tile Service, Nokia Here Map Service, and Stadia Maps) do not support proxy authentication mode NTLM.
If you are seeing SSL or certificate-related errors, FME Form's truststore may not include the root CA used by the map tile server. Some newer root CAs, such as Sectigo Root E46 (introduced in 2024), are not bundled with FME Form and must be imported manually. Please refer to the FME documentation on managing trusted certificates or contact technical support for assistance.
If you continue to experience issues, please contact technical support. When contacting support, please attach the following two log files. First, please run proxytest.fmw. After running the original workspace, please open the HTTPCaller transformer properties and change the URL to a website that your internal network will allow, save the workspace with a different name and rerun the workspace. For both tests, please share the log files when you submit a support request.
