FME and SQL Server Troubleshooting Guide
Liz Sanderson
Liz Sanderson
Microsoft SQL Server formats let FME store and retrieve data from a SQL Server database. Another useful resource is the SQL Server database Quick facts found in the documentation.
For introductory information on using SQL Server with FME, visit the SQL Server Tutorial series.
Starting in FME 2025.2, many formats that support both spatial and non-spatial data have been combined into a single reader or writer. For an up-to-date list of the formats this change has been applied to, please see Combined Spatial and Non-Spatial Readers and Writers.
Checklist
Are you having problems finding the SQL Server formats in FME?
  • Do you have the correct Operating System? SQL Server is available on Windows. If you are using a Linux or Mac machine, use the Microsoft SQL Server (JDBC) Reader/Writer.
  • Do you have the correct license edition? FME Form Pricing
  • Do you have the required Native Client?
    • FME tries to connect first with the Microsoft SQL Server 2012 Native Client; if it can't find 2012, it will try again using the 2008 Native Client.
    • SQL Server Native Client 2012 also works with SQL Server 2014 and SQL Server 2016.
Are you having problems connecting to a SQL Server database?
  • Are you using SQL Server Authentication or Windows Authentication? SQL Server Authentication uses credentials created and stored in SQL Server. With Windows Authentication, identification is confirmed through the Windows principal token; credentials aren't needed.
  • Have you tried the alternative format? If using SQL Server (MSSQL_ADO), try the JDBC format.
  • Can you connect outside of FME?
  • Is FME returning "SSL Provider: The target principal name is incorrect." Are you using only the database server hostname? Try using a fully qualified domain name, for example: hostname.mydomain.com
Are you having problems reading from SQL Server?
  • Does your table contain geometries? Read spatial tables from your database using the SQL Server Spatial Reader. You can read non-spatial tables using the SQL Server Non-Spatial Reader. Reading a spatial table with the non-spatial reader will not successfully read in the geometries.
  • Are your SQL Server tables not showing in the Table List?
    • Confirm you have permission to access that schema by connecting to SQL Server outside FME and viewing the tables in the schema.
  • Is Microsoft SQL Server 2012 Native Client installed?
Are you having problems writing to SQL Server?
  • Failed to Open Writer? Ensure the connection parameters are correct. FME does not check for the correct parameters when adding a Writer unless a user tests the connection. Ensure that you have the required permissions to write to the table. Ensure Microsoft SQL Server 2012 Native Client is installed.
  • Failed to write a feature of type, Argument Exception: 24200
  • Could not commit row locally? Check the data you are writing to confirm it follows the constraints defined by an existing table in SQL Server.
  • Are you using Bulk Insert? Bulk Insert can only be used for INSERTS when writing to SQL Server. For UPDATES or DELETES, Bulk Insert has to be turned off.
Are you having problems with SQL Server and Geometry or Geography?
Additional Resources
Advanced SQL Server Use
Advanced Writing Techniques
Performance Tuning
If you are not experiencing a specific issue with SQL Server but want to improve performance, please refer to Write Order and FME Performance for a detailed guide on improving Writer performance. Additionally, the Performance Tuning FME contains useful information for improving performance.
Request Technical Support
If you were not able to resolve the issue and need further technical support, please contact our support team by completing and submitting this Support Request Form.
When submitting a support request, please provide the following information (as applicable) in order to help us to provide a timely response:
  • FME log file
  • Source and destination datasets, or a small data sample. It may be necessary to capture the data via a Recorder transformer
  • FME Workspace
  • FME version and build number (preferably a screenshot of Help > About)
  • FMEReport.html (See here)
Once you submit the form, we will contact you to quickly resolve your technical issues.
