FME Fails to Write Coordinate System to Autodesk Map 3D Dataset
Liz Sanderson
Liz Sanderson
Versions affected
FME 2020.0 and prior versions are affected. For FME 2018+, please ensure you are using 64-bit FME since the Autodesk AutoCAD Map 3D Object Data Writer is 64-bit only.
Symptom
When writing features with a coordinate system using the Autodesk AutoCAD Map 3D Object Data Writer, the coordinate system is dropped in the AutoCAD Map 3D Object Data output.
In FME 2019-2020.0, the following warning is generated in:
Object Data Writer: Detected coordinate system in input data. This coordinate system will be dropped in the destination file
Resolution
The issue has been resolved in FME 2020.1 and higher. You can find the latest FME here.
Workarounds for FME 2020.0 and prior
The "Coordinate System Storage" parameter controls whether the AutoCAD Map 3D Object Data Writer will store the coordinate system of its features. The coordinate system can be stored inside the output AutoCAD file as an Esri Well Known Text (in an ESRI_PRJ entry in an internal dictionary in the file), according to Esri specifications. It can also be stored externally in a companion Esri .prj file that shares the output AutoCAD file's base name, but has a .prj extension.
Comments
0 comments
