FME Version
Known Issue ID | FMESERVER-17957 |
Feature | FME Flow Projects |
Product | FME Flow |
Versions Affected |
2025.x 2024.x 2023.x 2022.x 2021.x 2020.x |
Status | Unresolved |
Issue
A non-admin FME Flow (formerly FME Server) user imports a project (.fsproject) but cannot view or modify the project’s contents.
Cause
Due to permission dependencies, when a user without the fmeadmin or fmesuperuser role imports a project that they did not create, they will not have the correct permissions to view the project or the project contents.
Workaround
After a project has been imported into FME Flow; a user with the fmeadmin or fmesuperuser role will need to share the project as well as share the contents of the project with the desired user.
To do this, as the FME Flow admin, navigate to Projects, then click on the Share button next to the desired project.
Share the project with the intended users or roles.
Note that after sharing the project, automations, topics, and apps will need to be manually shared.
After the project has been shared with the desired user, the user can let the fmeadmin know which content permissions they are still missing (if any) by viewing the project and noting the red exclamation mark.
Comments
0 comments
