Install FME Flow for Docker
Liz Sanderson
Liz Sanderson
These are the steps to install FME Flow for Docker.
1. Install Docker
Follow the installation guide for your operating system:
https://docs.docker.com/engine/installation/
Note: FME Flow for Docker needs Docker Engine and Docker Compose installed. Both are included in Docker for Mac and Docker for Windows. Detailed instructions to install both on Linux can be found here.
2. Download docker compose file
We have docker compose files for several versions of FME Flow ready to download.
Here is more info in our Documentation for FME Flow for Docker.
3. Run docker compose
Open a command line tool and run the following command:
docker compose up -d
Navigate to https://localhost/ in your favourite browser and enjoy FME Flow for Docker!
Note: On Windows you might need to re-start after the docker install to ensure the %path% is set correctly to docker which is by default: C:\Program Files\Docker\Docker\Resources\bin
Note: Please note that docker compose should be used now instead of docker-compose
Don't forget to check out some useful commands for FME Flow for Docker.
