No FME Engines Available After Adding Network Based Resource
Liz Sanderson
Liz Sanderson
Versions affected: FME 2018.0 and prior versions which allow network resources
Version resolved: FME 2018.1 and newer
Problem
After adding a Network Based Resource to FME Server there are no FME Engines available to run jobs. FME Engine logs include the error message:
FME Engine failed to register with FME Server <host> on port 7070. Failed to verify message authenticity
Cause
The problem is caused by international characters in the UNC path to the Network Resource. For example the path: \\fs2\Pserv\Temp\Accént would cause this problem.
Solution
As of FME Server 2018.1+ this issue has been resolved. In FME 2018.0 and prior, the only workaround is to remove and not use network paths which include international characters.
Comments
0 comments
