PostGIS Error if Access Not Granted to Geometry Table
Liz Sanderson
Liz Sanderson
Consideration
An error message similar to one of the examples below is received:
"Error executing SQL command ('select * from "table_name" where false limit 0'): 'ERROR:  current transaction is aborted, commands ignored until end of transaction block'"
"Error executing SQL command ('SELECT f_table_name, f_geometry_column, coord_dimension, srid, type FROM geometry_columns WHERE f_table_schema = 'schema_name' AND f_table_name = 'table_name''): 'ERROR:  permission denied for relation geometry_columns'
Writer failed in write() call
f_21(CreationFactory): Writer failed in write() call"
Why This Happens
Users may not have permission to access the reserved tables that PostGIS requires, specifically the view geometry_columns. The PostGIS writer expects to be able to read the geometry_columns metadata view to determine how to write the spatial data.
How to Resolve This
Issue the following statement in the PostGIS database:
GRANT SELECT ON public.geography_columns TO PUBLIC ;
