Known Issue ID | FMEENGINE-37309 |
Discovered | 2012 |
Affects | All FME Desktop Versions |
Resolved | N/A |
Symptoms
When writing a web map or raster tileset with Dataset Fanout turned on, performance considerably slows down when writing and RAM usage skyrockets.
Cause
A dataset fanout re-arranges the order of tiles, and also requires all tiles to be accumulated before writing begins, which results in slow performance.
Resolution
At this time it is recommended that Dataset Fanout not be used when writing raster tiles.
Comments
0 comments
