Tutorial: Microstation Transformations
Liz Sanderson
Liz Sanderson
This tutorial focuses on translating between Microstation DGN formats. The first two examples move CAD data to and from GIS (specifically, a geodatabase). The remaining examples focus on working with geometries specific to the DGN format.
Articles
CAD to GIS: Convert Parcel Lines and Text from DGN to Geodatabase
Build polygons from lines, perform overlays, and transfer text values to their corresponding lines in this common CAD-to-GIS transformation.
GIS to CAD: Convert Parcel Polygons and Lines from Geodatabase to DGN
Create text features and style them, style polygons, as well as create and map attributes in this basic GIS to CAD transformation.
Reading Microstation (DGN) Tags with FME
Tags are a MicroStation feature that allows the user to attach non-spatial attribute information to DGN elements. They can be read as FME attributes using parameters on the DGN Reader.
Writing Microstation (DGN) Tags with FME
Tags are a MicroStation feature that allows the user to attach non-spatial attribute information to DGN elements. They can be written to MicroStation design files by creating a series of format attributes that define tags and tag sets, as well as user attributes that store tag values.
Handling Microstation (DGN) Dimensions
Dimensions are a type of MicroStation element (geometry). They are a form of annotation that depicts measurements on a CAD drawing. FME can read dimensions, and they can be created within an FME workspace by defining a series of FME format attributes.
Writing Microstation (DGN) Text Nodes with FME
Write Bentley MicroStation text nodes (multi-line text) with FME by defining the text as a list attribute. A list attribute in FME is a way to store multiple values for an attribute. Each value in the list becomes a line of text in the text node.
Microstation Text Styles in FME
Set text styles in a translation from Esri Shape to Microstation DGN V8, using FME.
