Configuring Datum Grid Shift Files for the USA
Liz Sanderson
Liz Sanderson
Overview
FME supports conversions between coordinate systems using different datums. Many datum transformations are not mathematically definable and require a grid of shifts. If you attempt to make a datum transformation of this kind without the appropriate grid shift file in place, FME will stop the translation. This article shows examples of how you can control which grid shift files are used and in what order.
To better understand how FME handles grid shift files, please refer to the online documentation.
In many cases, you need to contact the responsible authority (provincial ministry, etc.) to obtain the grid shift file. We are not always allowed to distribute them ourselves.
How Grid Shifts are Configured in FME
When converting datums, FME chooses the grid shift file to use from the list configured in Tools - FME Options - Coordinate Systems in the appropriate Grid Transformation.
HARN / HPGN Network in North America
When this was originally designed, there were only six HPGN files (HARN used to be called High Precision GPS Network, and that's why the files are named *HPGN.las). At the time, in all cases of overlap, the results were the same from any overlapping file, but this is no longer true. The design was intended to make HARN look like one datum and not preclude converting data that might extend beyond or over a grid file boundary. By making a selected wihpgn.las (Wisconsin) the first entry, for example, it becomes the default file.
If you only need high precision in one geographic region, for example, the state of Wisconsin, you could remove the other entries and gain a slight performance improvement as well as not have to worry about grid shift file order.
This same principle applies to NAD83, for example. The alaska.las files, the conus.las files, and the hawaii.las files are all listed in the Grid Transformation dialog. Users can order the files as needed. Thus, NAD83 is a single datum, and the system avoids prompting for which file to use.
Grid Shift Files by State
Here is a listing of States and their associated grid shift files.
For more background on NADCON and a complete list of US grid shift files, see State File Name
  Alabama                         ALHPGN
  Arkansas                        ARHPGN
  Arizona                         AZHPGN
  California                      CNHPGN    (Above 37 degrees latitude)
  California                      CSHPGN    (Below 37 degrees latitude)
  Colorado                        COHPGN
  Florida                         FLHPGN
  Georgia                         GAHPGN
  Hawaii                          HIHPGN
  Idaho-Montana                   EMHPGN     (East of 113 degrees longitude)
  Idaho-Montana                   WMHPGN     (West of 113 degrees longitude)
  Iowa                            IAHPGN
  Illinois                        ILHPGN
  Indiana                         INHPGN
  Kansas                          KSHPGN
  Kentucky                        KYHPGN
  Louisiana                       LAHPGN
  Maryland - Delaware             MDHPGN
  Maine                           MEHPGN
  Michigan                        MIHPGN
  Minnesota                       MNHPGN
  Mississippi                     MSHPGN
  Missouri                        MOHPGN
  Nebraska                        NBHPGN
  Nevada                          NVHPGN
  New England                     NEHPGN     (CT,MA,NH,RI,VT)
  New Jersey                      NJHPGN
  New Mexico                      NMHPGN
  New York                        NYHPGN
  North Carolina                  NCHPGN
  North Dakota                    NDHPGN
  Ohio                            OHHPGN
  Oklahoma                        OKHPGN
  Pennsylvania                    PAHPGN
  Puerto Rico-Virgin Is           PVHPGN
  South Carolina                  SCHPGN
  South Dakota                    SDHPGN
  Tennessee                       TNHPGN
  Texas                           ETHPGN     (East of 100 degrees longitude)
  Texas                           WTHPGN     (West of 100 degrees longitude)
  Utah                            UTHPGN
  Virginia                        VAHPGN
  Washington-Oregon               WOHPGN
  West Virginia                   WVHPGN
  Wisconsin                       WIHPGN
  Wyoming                         WYHPGN
