Symptom
When FME Server is deployed in Azure with the Azure Load Balancer, and the load balancer is internal, or private (the load balancer does not have a publicly accessible IP address), FME Server may work intermittently or not at all.
If there is only one FME Server core/web VM present behind the Azure Load Balancer, the FME Server web ui will be accessible from other VMs, but no jobs will run. From the FME Server core/web VM, the FME Server web ui will not be accessible.
If more than one FME Server core/web VM is present behind the Azure Load Balancer, FME Server may work intermittently.
Cause
This is a limitation of Azure Load Balancer (internal/private).
Accessing the Load Balancer from the same VM and Network interface.
When FME Server is accessed from the core/web VM, the web ui will not load.
Submitting jobs from an accessible web ui will fail, as the FME Server core will be making a request to itself through the load balancer.
Resolution
1. Add a second NIC to FME Server Core virtual machine(s)
This blog outlines workarounds to this limitation.
Adding a second NIC to the FME Server core/web VM, and routing outbound traffic through the second NIC resolves this issue.
For steps, please refer to Azure documentation:
Add network interfaces to or remove network interfaces from virtual machines.
Configure the VM operating system to use multiple network interfaces properly: Windows Linux
2. Use Azure Application Gateway
Azure Application Gateway is a web traffic load balancer that enables you to manage traffic to your web applications. It does not have the same limitation as Azure Load Balancer.
Comments
0 comments
