GDAL/PROJ Library Updates Affect Coordinate System Handling
Liz Sanderson
Liz Sanderson
Many parts of FME rely on GDAL, both directly and indirectly. The migration to GDAL 3 and PROJ 6 in FME 2020, has primarily altered behavior that has to do with either storing a description of a coordinate system or recognizing a coordinate system description.
What is Affected?
These changes affect the following FME components:
  • Any reader/writer where a coordinate system is stored with the data
    • Includes Well Known Text formats and Esri WKT, especially if an uncommon coordinate system is used
    • Almost all GDAL-based formats
    • May include formats that use an authority code to look up coordinate systems
    • Does not include formats that always use the same implied coordinate system (for example, most geospatial-database-as-a-service web platforms just use LL-WGS84).
  • A GeoTIFF reader/writer or a reader/writer that contains GeoTIFF specifications
  • Any use of the CoordinateSystemDescriptionConverter transformer
  • Use of coordinate systems based on the South American Datum of 1969
  • Use of coordinate systems based on Militar-Geographische Institut (Austria)
  • Any FME components that consume WKT in another format
If this migration results in your workspaces breaking, please contact Safe Support.
