Known Issue: Third-Party Plug-in Incompatibility
Liz Sanderson
Liz Sanderson
FME Version
Known Issue IDFMEENGINE-73151
DiscoveredFME 2022
AffectsFME 2022.0 and newer
ResolvedSee the resolution section
Symptom
A message similar to the following will appear in the log when FME 2022.0 attempts to load a C++ plug-in compiled with FME 2021 or older:
FME API version of module 'PLUGIN’ is '3.8 20200115', and it is incompatible with FME internal API version '4.0 20220317'
where 'PLUGIN' is the name of the third-party plugin (eg. gti/GTI_GTViewer)
Cause
The C++ APIs for developers have undergone some changes for FME 2022.0 and newer. Reader/Writer and Transformer plug-ins written in C++ will need to be recompiled with FME 2022 in order to be compatible with FME 2022 and newer.
Resolution
If you encounter this issue, please contact the developer of the third-party plug-in to obtain an updated version of the plug-in, compiled with the FME 2022.0 or newer.
Comments
0 comments
