| Known Issue ID | FMEENGINE-78741 |
| Feature | Parallel Processing |
| Product | FME Form |
| Versions Affected | 2023.0.0 |
| Status |
Resolved 2023.0.1 |
Issue
In FME Form 2023.0 licensed with a floating license server. Using existing or new FME workspaces with transformers/custom transformers configured to use parallel processing generates the following error message:
WARN |Parallel processing is not enabled by the current FME license
Additional messages associated with the Transformer being used may also be seen, for example:
INFORM|DEMCreator: The Parallel processing level of `MODERATE' has requested `4' workers
INFORM|DEMCreator: Parallel processing has been limited to `0' workers
Cause
Changes to FME Licensing in FME 2023 created an inconsistency with the Parallel Processing subsystem.
Resolution
Upgrade to FME 2023.0.1 is recommended. (Build 23326 or greater)
