Introduction to the MapnikRasterizer
Liz Sanderson
Liz Sanderson
The MapnikRasterizer transformer lets you generate high-quality cartographic rasters using Mapnik, a free toolkit for rendering maps. In an FME workflow, the transformer accepts vector or raster data through the input ports, generates a stylized map based on user-defined parameters, and outputs a raster through the output port.
The map below was generated and styled using the MapnikRasterizer:
This article will cover step-by-step instructions for building an FME Workspace that uses Mapnik to generate a stylized raster map. At the bottom, you can download additional workspaces to try more Mapnik styling examples.
How the MapnikRasterizer Works
Mapnik Symbolizers handle styling, which you define in the transformer parameters. The following table outlines what styling options you can set in each Symbolizer. For example, using the Polygon Symbolizer, you can set the color, smoothing, and compositing.
  Color Style Positioning Smoothing Properties Compositing
Building x x       x
Line x x x x   x
Line Pattern       x x x
Markers x   x x x x
Point     x   x x
Polygon x     x   x
Polygon Pattern       x x x
Raster         x x
Shield x   x   x x
Text x   x   x x
The styling options let you set the appearance using a color and opacity or a raster texture/pattern, add an offset and other positioning adjustments, smooth lines and edges for better aesthetics, and more. "Compositing" defines how layers interact, similar to blending modes in graphics editors like Photoshop or GIMP, and includes masking operations (e.g., Src-Over) and blending operations (e.g., Multiply).​​​​
Many styling options allow conditional values, where you can use a table of test conditions to assign values. Check the Mapnik Symbology documentation for full details about Symbolizers.
Files
Additional files are available on the right-hand side of this article.
Step-by-Step Instructions
In this scenario, we will create an FME workspace that reads vector geometry from a SpatiaLite database, uses Mapnik to style the geometry, and generates a raster as a PNG. The source dataset contains a single polygon, and we will use multiple Mapnik Symbolizers within a single transformer to style it.
Follow the steps below to create the workspace from scratch, or open the Finland1.fmwt template in MapnikTutorial.zip to view a completed version.
Part 1: Basic Styling
In Part 1, we will walk through the MapnikRasterizer parameters and style a Finland map by setting the background, extents, and geometry colors. This basic styling will help you get familiar with Mapnik Symbolizers. Part 2 covers more sophisticated styling.
1. Generate a Workspace
Open FME Workbench and generate a new workspace with the following parameters:
  • Reader Format: SpatiaLite
  • Reader Dataset: C:\<Tutorial Download>\source\finland.sl3
  • Writer Format: PNG (Portable Network Graphics)
  • Writer Dataset: C:\<Tutorial Download>\finland-styled
  • Workflow Options: Static Schema
Click OK to generate the workspace. The canvas will have a reader feature type on the left and a writer feature type on the right.
2. Add a MapnikRasterizer Transformer
Click anywhere on the canvas and begin typing "MapnikRasterizer". Add the transformer to the canvas and connect it between the source and destination feature types. The workspace should look like this:
Note that MapnikRasterizer has dynamic input ports, meaning it generates a new input port for each feature stream connected to it.
3. Open the MapnikRasterizer Parameters
Double-click the transformer to open its parameters. This dialog has several sections, which we will configure as follows.
(a) The "Group Processing" section includes "Group By" mode, a setting that relates to performance and can usually be left as-is. Leave this unchecked.
(b) The "Rendering Rules" section tells Mapnik how to style the input features. This is where you use Mapnik Symbolizers. Layers are drawn in the order that they appear in this table, with the top drawn first. First, add a rule to style the geometry using the Polygon Symbolizer:
  • Input Port: finland
  • Symbolizer: Polygon
  • Style: Click "Edit..."
    • Color: Click [...] and choose Green; set the opacity to 1 (1 is opaque; 0 is transparent)
    • Leave the Smoothing and Compositing parameters as-is
This rule will use Mapnik's Polygon Symbolizer to make the polygon Green. Now add a second rule:
  • Symbolizer: Line
    • Color: Click [...] and choose Yellow; opacity 1
    • Style: set Width (Pixels) to 6, Join to Round, Cap to Round, Miter Limit to 4
    • Positioning: set Offset to 0
    • Smoothing: set Gamma to 1.0, Gamma Method to Power, Smooth to 0.25, Rasterizer to Full
    • Compositing: set Compositing Operation to Src-Over
This rule will use Mapnik's Line Symbolizer to treat the input polygon as a line and make it Yellow, with other styling applied to make the line appear wide and smooth.
(c) The "Raster Properties" section defines the number of rows and columns or cell size, as well as the interpretation type (RGB24 or RGBA32). Set the following raster properties:
  • Resolution Specification: Cell Spacing
  • Cell Spacing: 2500
  • Interpretation Type: RGB24
(d) The "Background" section allows setting the background image or color and opacity.
  • Color: Click [...] and set the color to Cyan
  • Color Alpha Value: 1
(e) The "Ground Extents" section allows you to manually set the extents of the output raster. By default, the extents are defined by the input features, but sometimes you need to adjust the map boundaries depending on how you styled it. For example, in the rasters below, the left one uses the input extents (default), while the one on the right uses manually set extents. The user has added a buffer to account for the wide line styling.
For this scenario, set the extents as follows:
  • Ground Extents: Specify ground extents
  • Minimum X: 3176500
  • Minimum Y: 6630000
  • Maximum X: 3743000
  • Maximum Y: 7790000
Tip: To find the extents you need, generate a bounding box that encompasses all features using the BoundingBoxAccumulator transformer, then buffer it with the Bufferer transformer. Then extract the box's min/max coordinates as attributes using the BoundsExtractor, log them using the Logger, and use the values in the "Ground Extents" section. You could also send the bounding box to the MapnikRasterizer as a polygon and set its rendering rule to full transparency, then let Mapnik automatically use this transparent box as the extents.
4. Run the Workspace
Run the workspace. The finland.sl3 dataset will be styled according to the MapnikRasterizer parameters and output to a PNG file in the finland-styled folder.
Part 2: Styling with Patterns and Text
Now that you are familiar with the MapnikRasterizer parameters, let's modify the Rendering Rules and add nicer styling to the Finland map, including using a raster pattern instead of colors and adding text.
Follow the steps below to modify the existing workspace from Part 1. The completed workspace for Part 2 is attached in MapnikTutorial.zip, named Finland2.fmwt.
1. Open the MapnikRasterizer Parameters in the Existing Workspace
In your existing workspace from Part 1 (or working from the Finland1.fmwt workspace), open the MapnikRasterizer parameters. We will use 5 Rendering Rules to style the input dataset.
2. Change the First Rule to Use the Polygon Pattern Symbolizer
First, create a Rendering Rule to style the Finland polygon with a nice image instead of solid green. Change the Polygon rule to have the following parameters:
  • Symbolizer: Polygon Pattern
  • Style: Click 'Edit...' and configure it as follows
3. Keep the Line Symbolizer Rule
Keep the next rule that uses the Line Symbolizer as-is. We will style the border as yellow.
4. Create a new Rule Using the Line Pattern Symbolizer
The third rule adds a boundary symbol pattern to the yellow border. Add a new rule with the following parameters:
  • Symbolizer: Line Pattern
5. Create a New Rule Using the Text Symbolizer
The fourth rule adds a label based on the data's "name" attribute (which we know contains "Finland"). Add a new rule with the following parameters:
  • Symbolizer: Text
The "Positioning" section has quite a few parameters, but you only need to set the following:
  • Character Spacing: 10
  • Avoid Edges: Yes
  • Placement: Interior
Leave the rest as-is and click OK.
6. Create a New Rule Using the Point Symbolizer
The fifth and final rule adds a flag to the middle of the image as a point. Add a new rule with the following parameters:
  • Symbolizer: Point
You should now have five Symbolizers configured, and the Rendering Rules section should look like this:
Click OK to close the MapnikRasterizer parameters.
7. Run the Workspace
Additional Examples & Downloads
Download these additional workspaces to see more Mapnik styling examples and experiment with different Symbolizers.
http_download_144432978632_6032.png LineStyling.fmw Creates various line styles using the Line Symbolizer, including dashed lines and different caps and joins.
http_download_1444329786572_6032.png Compositing.fmw Styles a line multiple times with different widths, and the layers are blended using a "Plus" compositing operation. Also applies smoothing.
rtaImage.png RapidTransitMap.fmwt Generates a transit map, including line and point styling, text labels, and a background orthophoto.
Screen Shot 2021-03-12 at 12.14.24 PM.png ConditionalStreets.fmwt Uses test conditions to set symbology based on an attribute value, e.g., styling main arteries vs. residential streets.
Screen Shot 2021-03-12 at 11.50.27 AM.png ExternalSymbology.fmwt Generates a labeled map using external symbology from an Excel file. You can also use this method to gather symbology from an external database.
http_download_1444329787325_6032.jpeg BuildingStyling.fmwt Adds a 3D element to a 2D map by styling buildings using a Height parameter and extruding polygons and text labels.
http_download_1444329787650_6032.png RandomSymbolPlacement.fmwt Uses a point cloud to randomly place symbols to represent natural features – in this case, tree symbols to represent a forest.
http_download_1444329788635_6032.png Textures.zip Applies random textures to polygons and lines.
http_download_144432978893_6032.png ContouredFaces.fmwt Creates contour art from a face image. Inspired by a collection of maps with faces made by Ed Fairburn.
Additional Resources
Webinar: The Secret to Mapnik Mastery
Blog: 5 Ways to Do More with Mapnik
