FME and Intergraph GeoMedia Compatibility
Liz Sanderson
Liz Sanderson
What GeoMedia formats does FME support and what versions of GeoMedia are supported?
Answer
Available Formats
For the context of this article, FME refers to both FME Desktop and FME Server.
FME supports reading and writing to GeoMedia Access and GeoMedia SQL Server Warehouses.  However, it is important to consider the bit version of FME when writing to GeoMedia Access Warehouses.  FME users (32bit & 64bit) do not need to have any version of GeoMedia installed on their systems to read from and write to compatible versions of GeoMedia SQL Server Warehouses.  FME users (32bit) do not need to have any GeoMedia installed on their systems to read from compatible GeoMedia Access Warehouses.   However, FME uses GeoMedia libraries for writing to GeoMedia Access Warehouses and so GeoMedia, which is 32bit, must be installed on the same system as FME 32bit.  This also means that FME 64bit can not be used to read or write to GeoMedia Access Warehouses.
Note that the 32-bit GeoMedia writer has been deprecated with the deprecation of 32-bit FME in 2022.0. If you need to access this writer, please use FME 2021.2 or prior.
Example Environments with GeoMedia installed
System 1: Windows OS 64bit, with FME 32bit
  • FME 32bit supports both Read & Write to GeoMedia Access and GeoMedia SQL Server Warehouses
System 2: Windows OS 64bit, with FME 64bit
  • FME 64bit supports Read & Write to GeoMedia SQL Server Warehouses
  • FME 64bit cannot read or write to GeoMedia Access Warehouse
Example Environments without GeoMedia installed
System 3: Windows OS 64bit, with FME 32bit
  • FME 32bit supports both Read from GeoMedia Access Warehouse and GeoMedia SQL Server Warehouses
System 4: Windows OS 64bit, with FME 64bit
Comment on Windows OS 32bit: Also supported with FME 32bit and would work with GeoMedia in the same ways as Windows OS 64bit.
Version Compatibility
FME support will be available for a GeoMedia version as long as Hexagon considers it still active.
This table provides an overview of GeoMedia versions supported by each FME version:
FME Version Geomedia 6.0Geomedia 6.1Notes
2009Read Access Warehouses          +          +1
 Write Access Warehouses (32bit)          +          +1,*
 Read SQL Server Warehouses          +          +
 Write SQL Server Warehouses          +          +
2010Read Access Warehouses          +          +1
2011Read Access Warehouses          +          +1
FME Version GeoMedia 2014GeoMedia 2015GeoMedia 2016Notes
2015.1.3Read Access Warehouses           +         +          +1
 Write Access Warehouses (32bit)           +         +          +1,*
 Read SQL Server Warehouses           +         +          +
2016.XRead Access Warehouses           +         +          +1
 Write SQL Server Warehouses           +         +          +
2017.XRead Access Warehouses           +         +          +1
 Read SQL Server Warehouses?         +          +
 Write SQL Server Warehouses?         +          +
FME Version GeoMedia 2017GeoMedia 2018Notes
2018.X
1
1, *
FME 2019.X is assumed to work with GeoMedia 2018
FME VersionFormatGeoMedia 2020Notes
2020.X, 2021.XRead Access Warehouses             +1
 Write Access Warehouses (32bit)             +1,*
* - Needs applicable GeoMedia software installed to write to Access Warehouse
1 - Only FME Desktop 32bit works with Access Warehouses
