Known Issue: Merged Feature Types Not Working In FME Server
Sienna Emery
Sienna Emery
FME Version
Known Issue ID
FMESERVER-16357 and FMESERVER-16348
Discovered
FME Server 2020.2 build 20817
Affects
FME Server 2020.2 build 20817 and FME Server 2021.0 build 21293
Resolved
2020.2 build 20824+, 2021.0 build 21296+, 2021.1 build 21520+, or  2022.0 build 22049+.
Symptom
After publishing a workspace to FME Server that contains a merged feature type reader it is not possible to run the workspace via the Run Workspace page or Automations. This should cause the workspace to fail in most cases, however, if it is an Oracle Reader, the log will look successful but no features will be read in.
Resolution
Users affected can upgrade to 2020.2 build 20824+, 2021.0 build 21296+, 2021.1 build 21520+, or  2022.0 build 22049+.
Please note that Automations previously created and restored into the fixed versions will need to have the user click “Apply” on the workspace node and save the Automation for the changes to be picked up.
Alternatively, users can use a normal parameter and a Feature Reader to read in the tables, as seen in the workspace attached.
Comments
0 comments
