Dynamic Workflows: Basics of Dynamics
Liz Sanderson
Liz Sanderson
Why Create Dynamic Workspaces?
Traditional FME Workspaces are tightly bound to the source and destination schemas:
A dynamic workspace breaks this dependence on schema, creating a universal layout that is designed to handle data regardless of the schema:
Components of a Dynamic Workflow
A number of components can be made dynamic in an FME Workspace:
Source Feature Types:
In the Reader, a source Feature Type can be configured to read any schema. This can be set using the Merge Filter parameter.
Destination Feature Types:
In the Writer, a destination Feature Type can be configured to write the schema defined at runtime.
There is a related function not discussed in this series: the feature type fanout. A fanout will split output data based on the value of an attribute at runtime. Read more about fanouts.
Common Uses for Dynamic Workflows
Dynamic workflows can be useful for cases like:
  • Applying a relatively simple data transformation to all data coming into a workflow, regardless of its schema (for example, clipping, format translations, coordinate transformations).
  • When the source dataset's schema is unpredictable or poorly defined.
  • Performing ad hoc data transformations on many input datasets.
  • When the destination format might vary.
  • When long-term maintenance of the workspace is required (for example, if new feature types or attributes are added to the source data, the workspace would not need to be changed).
