Earthquake KML Streaming Example | Data Streaming in FME Flow
Liz Sanderson
Liz Sanderson
Streaming data via a URL is a great way to share data with someone who does not have FME installed, or to share a dataset that is local on your computer or comes from a live feed. You could also embed the direct URL into another project, such as a web map. For an example on how to create an FME Flow App that utilizes data streaming, please see the article on FME Flow App Examples.
In this example, we review the demo workspace included with FME Flow in the Samples repository.
The Workspace
Let’s review what the workspace is doing. You can either download the workspace from the Files section of this article, or, if you have FME Flow installed, download the earthquakesextrusion.fmw from the Samples repository.
The workspace is fairly straightforward: it reads a GeoJSON feed from USGS, then, based on the magnitude listed in the JSON, raises it to the power of 10 to exaggerate the data.
Next, the workspace uses the KMLDiagrammer custom transformer, available for download from the FME Hub. This transformer creates features that appear in 3D when opened in Google Earth.
Once the earthquake extrusions have been created, they are then sorted by magnitude and colored red. Finally, the data is written out to OGC/Google KML.
Set Up Data Streaming in FME Flow
Data streaming setup begins in FME Workbench when the data is uploaded to FME Flow. When using the FME Flow Publishing Wizard, on the final page where you Register Services, be sure to enable Data Streaming. If you have more than one writer, click on Edit to confirm which writers you would like to use for the output.
Once the data has been published to FME Flow, navigate and log in to FME Flow to continue setting up the data stream.
In FME Flow, navigate to the Run Workspace page, then select Samples as the Repository, earthquakesextrusion.fmw as the Workspace, then set the Service to Data Streaming.
If you clicked Run, the workspace would run, and quakes.kml would be downloaded to your computer. Instead, let’s build our URL to share with other users.
Ensure that the Guest role is enabled on your FME Flow, then change the following URL to your FME Flow hostname:
<hostname or FME Cloud URL>/fmedatastreaming/Samples/earthquakesextrusion.fmw
Data Attribution
The data used here are from the USGS (United States Department of the Interior). It contains information available in the public domain.
