Create an FME Flow Azure Entra ID (Active Directory) Web Connection in FME Form
Richard Mosley
Richard Mosley
To create an FME Flow web connection in FME Form that uses Azure Entra ID, the FME Flow Administrator must first create a web service to share among FME Form users. FME Flow web connections can publish workspaces and transformers in FME Flow. The Microsoft Azure Active Directory web service template is generic and must be updated to allow an Azure Entra ID connection in an FME Flow Web Connection from FME Form.
Before following these steps, complete the steps in Configure FME Flow for Azure Active Directory.
Step-by-Step Instructions
Part 1: Create a Registered App
  1. From the Azure Entra ID portal, select Manage > App registrations > + New Registration, and complete the following fields:
    • Name: Provide a name for the registration, such as FME Form
    • Supported Account Types: Specify whether to allow FME Flow to interact with a single Entra ID tenant or multiple Entra ID tenants. We recommend setting up a single-tenant App Registration so only users from your tenant can sign in.
    • Redirect URI:
      1. Type: Public native/client (mobile & desktop)azure_web_desktop_app.png
      2. URI: https://localhost (FME Form needs to keep the redirect local)
  2. Click Register.
  3. An overview page of the application registration opens. Navigate to Overview > Essentials, and record the Application (client) ID and Directory (tenant) ID.
  4. Navigate to API permissions and confirm a Microsoft Graph User permission is listed.Read Delegated permission for the app.
    • Grant admin consent to User. Read for the Entra ID tenant name.
Part 2: Create a Web Service
  1. In FME Workbench, go to FME Options → Web Connections → Manage Services (On Mac: Preferences → Web Connections → Manage Services)
  2. Click on the '+' button, then Create From → Microsoft Azure Active Directory (Template)
  3. Give the web service a name and configure it:
    • Client ID: the client ID from your app registration
    • Client Secret: leave empty and check the optional box on the right.
    • Redirect URI: https://localhost
    • Authorization Parameters URL:
      • If you configured a single-tenant app in Azure, replace [TENANT_ID] with your tenant ID and update the scope to the permissions you created in part 1. If you registered a multi-tenant app in Azure, use the ‘common’ instead of the tenant ID.
      • Replace [OAUTH_SCOPE] with https://graph.microsoft.com/User.Read
      • Optional: Additional scopes can be added if required by your organization, but they are generally not necessary. Separate each with a space. See Microsoft's documentation on scopes and permissions.
        Example:
        https://login.microsoftonline.com/<Tenant_id>/oauth2/v2.0/authorize?response_type=code&scope=offline_access https://graph.microsoft.com/User.Read
    • Retrieve Token Parameters URL: replace [TENANT_ID] with your tenant ID and remove the scope query string parameter
      Example:
      https://login.microsoftonline.com/<Tenant_id>/oauth2/v2.0/token
    • Refresh Token Parameters URL: use the same URL as the Retrieve Token Parameters URL
In FME Form 2026.3 and later, the scope query string parameter is in the Request Format field for Retrieve Token Parameters and Refresh Token Parameters, not in the URL.
  1. Click Apply. Test the web service using a non-admin user's Azure Entra ID credentials. When the test succeeds, proceed to part three.
Part 3: Create a Web Connection
  1. In FME Workbench, go to FME Options → Web Connections (On Mac: Preferences → Web Connections)
  2. Click on the '+' button and create the connection:
    1. Set the Web Service to FME Flow and give the connection a name
    2. Specify your FME Flow URL in the form https://<HOSTNAME>:<PORT>
    3. Set the Authentication method to Azure Active Directory
    4. Under the Azure Active Directory Connection, choose to Add Web Connection.  (Create a new Azure Web Connection from the Web Services to use in the FME Flow Web Connection)
    5. Use the web service created in Part 2 and give the connection a name
    6. Authenticate → Select your Azure Entra ID/Active Directory account (Make sure the account has been imported into FME Flow first)
    7. Authenticate the FME Flow Azure Active Directory Web Connection
  3. Test the connection by publishing a workspace to FME Flow, or use it in one of the FME Flow Transformers
Part 4: Share the Web Service
To let other FME Form users create an Azure Active Directory Web Connection to an FME Flow, the Administrator must share the Web Service by exporting it; users can then import it into their application.
Export the Web Service
  1. In FME Workbench, go to FME Options → Web Connections → Manage Web Services (On Mac: Preferences → Web Connections → Manage Services)
  2. Select the service created in part 2, scroll to the bottom, and click 'Export...'. Choose a location to save the file. Enable password protection to encrypt the file and keep it secure.
Import the Web Service
  2. Click on the '+' sign → Import From File
  3. Select the file provided by your administrator and specify the password
  4. You can now follow Part 3 to create a web connection.
