FME Version
Known Issue ID | FMESERVER-17228 |
Feature | FME Flow Installation |
Product | 32-bit FME Server |
Versions Affected | 2021.x |
Status | Deprecated |
Issue
While installing the 32-bit FME Server, the installation seems successful, but FME Server will not start. In Windows Services, the FME Database Service will not be visible.
Cause
The 64-bit version of the C++ runtime is needed in the installer because Postgres is now 64-bit, but we only install the 32-bit version of the C++ runtime with the 32-bit installer.
Resolution/Workaround
The workaround is to install the 64-bit version of the C++ runtime before running the installer. It can be download from here: https://support.microsoft.com/en-us/topic/the-latest-supported-visual-c-downloads-2647da03-1eea-4433-9aff-95f26a218cc0.
Please note that Safe Software's technical support for FME 2021.2 will end in August 2025. This means that 32-bit versions of FME will no longer be supported. To continue to receive technical support for FME, please upgrade your operating systems to 64-bit and download a newer version.
Comments
0 comments
