Symptom
Executing a SQL Query in the Oracle reader, OracleQuerier or other FME transformer returns an error:
error was
`ORA-00911: invalid character
Cause
This can be caused by including the semi-colon (;) on the SQL statement, or possibly inserting TABs and other special characters that may be included in the SQL statement if you have cut and pasted from a SQL editor.
Resolution
Remove the ';' or other special characters for single line SQL statements.
The FME "SQL Statement to Execute Before/After Translation", SQLCreator, and SQLExecutor (retired SQLQuerier) do support multiple SQL statements.
In this case include the FME_SQL_DELIMITER <delimiter> as the first line in the SQL block (typically the delimiter is a semi-colon ";").
