Installer error code is 2738
Liz Sanderson
Liz Sanderson
FME Version
Symptom
When running the intaller for FME Desktop the error "The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738." is shown.
Cause
The VBScript engine was not registered correctly.
Resolution
Solution 1
It is not enough to reinstall the VBScript. First remove the keys in the registry. The VBScript engine can be quickly registered by following these steps:
1. Run Command Prompt as administrator:
  • Start Menu -> All Programs -> Accessories
  • Right click on Command Prompt and select Run as administrator
2. Run the following command:
 If you are using 32-bit version of Windows Type cd %windir%\system32 into the Command Prompt and hit Enter If you are using 64-bit version of Windows: Type cd %windir%\syswow64 into the Command Prompt and hit Enter
3. Type regsvr32 vbscript.dll into the Command Prompt and hit Enter.
Solution 2
If the above solution does not work, try the following alternative steps:
If you are using 32-bit version of Windows:
2. Type the following command in the prompt:
 reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f, then hit Enter.
OR
 Remove the HKEY_CURRENT_USER using REGEDIT.
3. Next, you must also type the following command: c:\windows\system32\regsvr32 vbscript.dll, then hit Enter.
2. Type the following command:
 reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f, then hit Enter.
OR
3. Next, you must also type the following command: c:\windows\syswow64\regsvr32 vbscript.dll, then hit Enter.
Also see http://blogs.msdn.com/b/heaths/archive/2007/05/31/windows-installer-errors-2738-and-2739-with-script-custom-actions.aspx
Problem and Solution first seen at http://groups.google.com/group/fmetalk/browse_thread/thread/b5594891c34d16ca
Comments
0 comments
