Line in Polygon
Liz Sanderson
Liz Sanderson
In this exercise, you will use the SpatialFilter to set a spatial predicate that will determine which line features intersect polygon features. The SpatialFilter compares two sets of features to see if their spatial relationships meet selected test conditions. The features being tested (Candidate features) are identified as having passed or failed the test. For example, if you have a roads dataset (lines) and want to extract all roads that pass through parks (polygons), you would direct the roads to the Candidate input port and the parks to the Filter input port.
Data Source
The first dataset is an Esri Shapefile containing the boundary of the Mount Pleasant neighborhood in the City of Vancouver.
The second dataset is an Esri Shapefile containing all of the roads in the City of Vancouver.
Step-by-step Instructions
In this scenario, you will merge MountPleasantClipBoundary polygon features with linear Street features and join attributes based on the spatial predicate, “Filter Intersect Candidate”. In this case, the Neighborhoods dataset is the filter because you want to extract all Streets that intersect the MountPleasantClipBoundary and merge their attributes.
The data used in this example can be found in the Files section of the article.
1. Create a New Workspace
Open FME Workbench and create a blank workspace.
2. Add an Esri Shapefile Reader
Add an Esri Shapefile reader to the canvas by clicking on the Reader button on the top menu bar or by going to Readers > Add Reader. In the Add Reader dialog, select Esri Shapefile as the Format, then for Dataset browse to the MountPleasantClipBoundary.shp dataset, which is available for download from the Files section of this article. Then click OK to finish adding the reader.
Add a reader to the canvas and set the following parameters:
  • Format: Esri Shapefile
  • Dataset: <path>\MountPleasantClipBoundary.shp
    • Click on the ellipses to navigate to the location of the file on your computer
Click OK to add the reader to your workspace.
3. Add Another Esri Shapefile Reader
Add another reader to the canvas and set the following parameters:
  • Dataset: <path>\Roads.shp
Click OK
4. Filter Spatially
To filter the data spatially, we will use a SpatialFilter transformer. Click on the MountPleasantBoundaryClip reader feature type to select it. Then add a SpatialFilter to the canvas by typing “SpatialFilter” to bring up the list of FME Transformers in the Quick Add Search. Select the SpatialFilter from the list of Transformers by double-clicking or by using the arrow keys and the Enter key to add it.
The MountPleasantBoundaryClip reader feature type will be automatically connected to the Base input port on the SpatialFilter. Connect the Roads reader feature type to the Candidate input port on the SpatialFilter.
Double-click on the SpatialFilter to open the parameters. For this example, we can accept the default values, but note that we are using Filter OGC - Intersects Candidate as the Spatial Predicate to Test, and that we are also merging the attributes.
5. Run Workspace
Connect an Inspector transformer to the SpatialFilter's Passed output port.
Run the workspace by clicking the Run button on the top toolbar, or by selecting Run > Run Workspace from the top menu bar.
After running the workspace, only the roads that are within/intersect the MountPleasantBoundaryClip dataset will be available, and the two datasets will have their attributes merged.
Data Attribution
