Dynamic Workflows with the SchemaScanner
Liz Sanderson
Liz Sanderson
As we’ve seen, dynamic workflows can obtain their schema from multiple locations.
One of those locations is within the workspace itself, and the SchemaScanner transformer is a key tool in enabling that.
The SchemaScanner, as the name suggests, scans incoming features and produces a schema from them. That schema can then be used in a dynamic writer. The schema is stored in a specific FME feature.
The schema produced by this transformer may differ from the reader schema due to workspace processes, such as attribute renaming, removal, or addition.
In this workspace, attributes are being added and removed from the reader schema
The SchemaScanner generates a new schema for the output, assigns it a name, and passes it to a dynamic writer. Notice how the schema feature passes from the SchemaScanner:Schema output port to the same writer input port as incoming data.
The dynamic writer is set up to recognize incoming schema features and will make use of them:
Notice how the Schema Source is set to “Schema From Schema Features” to inform the writer from where the schema is to be obtained. Also, notice the parameter that defines the schema name. This handles the situation where the same writer is fed multiple schema features.
Now the data will be written to the output CSV dataset with the schema as modified by the AttributeManager.
Definition: A Schema Feature stores information about a schema that can be passed to a writer. The information is held as a series of list attributes called attribute{}.name and attribute{}.fme_data_type
Schema features are generated by the SchemaScanner transformer, but also by the FeatureReader transformer, the Schema (Any Format) reader, and even the AttributePivoter transformer!
Going back to the SchemaScanner, let’s look at the parameters:
The important things to note here are:
  • The transformer is set up to output the schema feature before any data features. This is vital. The writer must receive the schema feature before any data features that make use of it.
  • The transformer is set up to exclude from the schema any attributes that contain fme_, csv_, or multi_. These are format attributes that we don’t really need in the output.
  • Attributes with empty (or null) values will be ignored; i.e., excluded from the output schema, just as if they’d been removed in the AttributeManager
  • The transformer has been instructed to detect dates in the incoming data. If this had not been set, values such as 20220812 would be interpreted as numbers rather than dates.
Step-by-step Instructions
The goal here is to transform some CSV data, with a dynamic schema that accounts for changes made to the data within the workspace itself.
1. Generate Workspace
Generate a workspace to translate from CSV to CSV. Set the Reader Dataset to Cedar Cottage.csv, which is in the Files section of the page. Set the Writer Dataset to an output location. Finally, set the Workflow Options to Dynamic Schema.
Run the workspace to load the data and inspect it to see what we have.
2. Create New Attributes
Add an AttributeManager transformer and connect it between the reader and writer feature types. We'll use it to create a new attribute called Hours, which combines the Open and Close attributes. Open the Text Editor for the Hours Value and set it to: @Value(Open) - @Value(Closed)
Delete the Open and Close attributes, since we no longer need them.
Be sure to create “Hours” above “Open” and “Close”; otherwise, the deletion occurs first, and Hours has no content. You can use the Up/Down arrows to move attributes.
You can run the translation again at this point, but the output will still have the same schema. That’s because it’s still coming from the reader, and proves why we need the SchemaScanner.
3. Add a SchemaScanner Transformer
Place a SchemaScanner transformer. Ensure it is after the AttributeManager and connect both the Output and <Schema> ports to the writer feature type.
Check the transformer parameters. Ensure that Output Schema Before Data Features is set to Yes.
For Ignore Attributes Containing, enter:
fme_|csv_|multi_
4. Modify Writer Parameters
Now open the parameters for the <dynamic> CSV writer feature type
Click the ellipsis [...] button to the right of the Schema Sources parameter. In the dialog, uncheck the box for Cedar Cottage and check the box for Schema From Schema Feature:
Now set the Schema Definition Name parameter to the attribute created by the SchemaScanner; fme_feature_type_name
5. Run Workspace
Your workspace should now look like this:
Run the workspace and inspect the output. It will look like this:
Note that the Open and Close attributes are missing, but there is an Hours attribute.
6. Save Workspace
Save the workspace. We'll use it as the starting point for the next exercise.
Data Attribution
