Getting Started with the CityEngineModelGenerator
Jovita C.
Jovita C.
ntroduction
The CityEngineModelGenerator is a transformer available on the FME Hub that allows you to create 3D models from CityEngine rule packages and input vector geometry.
The transformer has two main functions: one that generates a configuration template based on a rules file, and the second that generates the 3D model based on input vector geometry, such as a building footprint and a CityEngine rule package file (.rpk).
The Generate Configuration Template option reads an input rules file and creates an attribute named _cga_attr_json, a JSON-formatted string containing the configurable parameters from the rules file. You can then configure the rule package by modifying the attribute in your workflow and use it to generate a desired model with the Generate Model action.
This tutorial assumes that you have some familiarity with Esri CityEngine and some working knowledge of JSON parsing in FME. The tutorial on Getting Started with JSON is a great starting point for learning how to parse and modify JSON in FME.
Requirements
Platform Support: The CityEngineModelGenerator is currently only supported on a Windows 64-bit platform
Licensing: The CityEngineModelGenerator, which uses CityEngine’s SDK, is available for free for non-commercial use; however, commercial use requires at least one commercial license for the latest Esri CityEngine version to be installed within the organization. Please see Esri's Licensing Information on the CityEngine SDK for further details.
Terminology
  • Rule Package: the *.rpk file that contains the CGA attributes
  • CGA (Computer Generated Architecture): a programming language that provides the rules or instructions for generating the 3D model
  • _cga_attr_json: the FME attribute containing a JSON string that displays the contents of the CGA attributes
Troubleshooting
When generating a model from a modified _cga_attr_json string, I am getting warnings about data type conversions (such as an int to a float). Should I be worried?
The data type in the CGA attribute is strict. This means that if a maxBuildingHeight has a type of “float”, the transformer will only accept an input value that is a float data type. FME will do its best to convert data types appropriately, so it’s likely that the wrong input type was provided and FME is handling it for you. Verify that the output is what you’re looking for, and then either correct the input or accept it as is.
Why did my feature appear in the rejected port?
Be sure to pay attention to what kinds of geometry your rule package applies to. For example, many rule packages may ask for a 2D vector building footprint or closed polygons to generate vegetation. A mismatched input for the rule package could cause features to be output from the rejected port.
Additional Resources
Where can I find sample rule packages to get started?
ArcGIS CityEngine Rule Packages
Esri PyPRT Examples on GitHub
