Files
- 700 KB
- Download
This example uses the Autodesk Revit reader with the Building Elements with Hierarchy data view to write to Trimble SketchUp and Adobe 3D PDF.
Source Data
This example originally uses a Revit Export file created from the basic sample project included in Revit 2013, using the FME Exporter plugin for Revit. The FME plugin is automatically installed with FME.
We cannot include the source data with this example; however, it should work with any Revit Export file you create from your own Revit projects.
If you do not have any Revit files on hand, you can download the buildingSmart Alliance Duplex Apartment COBie sample. The Revit RVT file can be downloaded from the buildingSmart Common Building Information Model Files page, in Project 1 - Duplex Apartment. Select the file 2011-09-14-Duplex-RVT.
Completed Workspace
Workspace Description
Write to PDF
1. Move Attribute to Geometry Traits
The Adobe 3D PDF writer creates a hierarchical 3D model from the source features. To retain the attribute information, we must move it from feature attributes to feature geometry traits using the GeometryPropertySetter. For more information, please see the FME Documentation on geometry traits.
2. Set Geometry Name
The Adobe 3D PDF writer identifies the feature using the geometry name. A second GeometryPropertySetter is used to set the geometry name to the Revit feature type, stored in fme_feature_type.
3. Fanout Features in 3D PDF Writer
The output Layer name is set to the fme_feature_type + 's', to create a Layer for each type of feature.
Write to SketchUp
1. Extract Feature Type to SketchUp Layer Name
The Revit feature type will be used to set the Layer Name in SketchUp, allowing for differentiation of the features.
2. Store SketchUp Layer Name as a Geometry Trait
The SketchUp layer name must be stored on the geometry as a trait.
3. Reproject to Local Coordinate System
In SketchUp, measurements are important, and it is convenient to have the model centrally located. We will use a CommonLocalReprojector to reproject to a local coordinate system centered around the model, with the units in meters. Vertical Handling must be set to 'Heights are relative to the ellipsoid or geocentric' in order to scale the Z values as well as the XY.
4. Write to SketchUp
SketchUp is a folder-based writer, so the output file name will be determined by the output feature type. To retain the Revit file name, we set the output feature type to fme_basename, which contains the root name of the source Revit file.
The output PDF and SketchUp models retain the Revit appearance.
Results in Acrobat
Results in SketchUp
The output features in SketchUp retain their original feature type, which is stored in the SketchUp Layer Name.
If you were using the Duplex_A example, this is what the output would look like in SketchUp Online.
